Old 07-27-2015, 12:17 PM   #1
Tgreen3724
Default A/F Ratio
454/425 Super Stock BBC running a two step button and footbraking. AF ratio runs about 16:1 on two step then dives all the way to 11:1 immediately after release of the two step button. Then two seconds into the run AF curve flattens out and remains in the 12.5 to 12.7 ratio range. Is this normal for the AF ratio to dive from 16 to 11 after the two step is no longer activated? Ratios remain under 12 for two seconds of run then flatten in the upper 12 range for remainder of pass. Is this normal? Thoughts?
Tgreen3724 is offline   Reply With Quote
Old 07-27-2015, 06:13 PM   #2
Kevin Panzino
Kevin Panzino's Avatar
Liked 748 Times in 137 Posts
Default Re: A/F Ratio
Yes, Mine does exactly what you describe, however I'm not seeing nearly that long for mine to get back above 12... p.m. me if you like.
Kevin
Old 07-27-2015, 06:29 PM   #3
Bob Shaw
Liked 316 Times in 61 Posts
Have you tried checking the A/F ratio without using the 2 step? Mine keeps getting richer the longer I am on the 2 step.
Bob Shaw V/SA 515
Bob Shaw is online now   Reply With Quote
Old 07-27-2015, 06:43 PM   #4
Tim Lisson
If you have the sensor towards the end of the collector, you will not read an accurate reading on the two-step, and it will always reflect a lean signal.
The fuel is puddling in the intake and after launch it should show rich due to the blast of fuel. Sounds like you could pull a little fuel out of it but then again, each combo likes something different.
Tim Lisson is offline   Reply With Quote
Old 07-27-2015, 09:10 PM   #5
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
The AF ratio is calculated by input from the O2 sensor. Wide or narrow it's still an O2 sensor. The O2 is seeing lean while on the limiter because the engine is missing & oxygen that normally gets used up in combustion, isn't. It would be interesting to see the curve on a run without the two-step.
Dave Noll, EF/S ,?/SA 6526
Old 07-30-2015, 08:20 PM   #6
MOTORSPORTS Innovations
MOTORSPORTS Innovations's Avatar
Liked 15 Times in 2 Posts
One of the key elements on this is where the O2 bung is located. In the collector, carb car, guaranteed crazy reading (on 2-step) - in a primary tube - it might be ok or will straighten out much more quickly. The reason for this the back-pulses of clear air coming into the collector at lower RPM's.
Big cube bracket cars can get away with it in the collector. Stock & SS - put it in the primary.
Also, EFI cars seem to have more stable O2 readings on the 2-step.
Here is a log of a car showing pretty stable O2 readings bungs are in primary tubes. BUT it is an EFI car.
www.motorsportsinnovations.com
MOTORSPORTS Innovations is offline   Reply With Quote
Old 07-30-2015, 08:59 PM   #7
Rob Petrie E395
Liked 216 Times in 77 Posts
How far down the primary should the 02 sensor be? If I were to try and put some in.
Old 07-31-2015, 09:06 AM   #8
10-12 inches form the cylinder head. A little closer is ok if necessary to deal with clearance issues.
Greg Kelley - 609-265-2110
Old 07-31-2015, 11:44 AM   #9
pbp1
Liked 27 Times in 6 Posts
No matter where you have the sensor mounted, the two step is skewing your readings. Misfires are always read as lean on the O2 sensor. I dont know exctly why but they do. What has helped me the most is looking at what the A/F ratio does immediately after you let go of the button. If it dives really rich, that tells you it was rich when it was on the 2 step. If it stays lean after you let go of the button, it was lean on the 2 step.
pbp1 is offline   Reply With Quote
Old 07-31-2015, 01:51 PM   #10
Ed Wright
Ed Wright's Avatar
A misfire in a street car does the same thing, often skews the fuel trims until fixed.
Reason is oxygen out the exhaust ports when misfiring. The wide band only knows oxygen content, and converts the oxygen level to air/fuel ratio. High oxygen = lean, to the wideband.
Ed Wright 4156 SS/JA
