Old 08-13-2015, 07:58 PM   #21
terry1
Liked 24 Times in 13 Posts
Smile Re: carb air entry pan for the Super 10
Thanks Danny. Speedway Motors site say it "fits Holley carbs".
Terry K
terry1 is offline   Reply With Quote
Old 08-13-2015, 10:02 PM   #22
Danny Ashley
Liked 110 Times in 29 Posts
Default Re: carb air entry pan for the Super 10
Terry:
Yes it does but Holley and Quadrajets both use a 5 1/8 air cleaner. The only thing to watch when using one on a Q-Jet, sometimes it requires a slight modification because the accelerator pump lever may hit. Also when used on a Pontiac carb, a hole needs to be drilled for the front vent tube. Easy fix for both.
Danny Ashley is offline   Reply With Quote
Old 08-14-2015, 08:12 AM   #23
terry1
Thanks Danny for the great info,as always.
By the way, my carb is working as good now as the day I got it back from you.
Terry Knapper
Old 08-19-2015, 10:45 PM   #24
Woodfin
Liked 288 Times in 109 Posts
Thanks goes out to Dick Ullrich [aks FED387] for a factory air filter base that works with the side hung float bowl.
Dick sent a full service package with attaching hardware and instructions. I like it when racers help racers.
See photos under the last page of Super 10 build thread
