Looking at building a 350/255. Would like to know what stall and gears?
Liked 13 Times in 7 Posts
Run the 2.75 gear metric trans with 5.13 rear gears, 9x30 92.5 rollout tires are what I think most if not all 250/280 '69's are running. I hope this helps.
Richard Grant 4988 STK |
#4 | |
Liked 5 Times in 5 Posts
Danny Durham |
Good advice from Danny. PTC would also be a good choice. You need good info on your car before ordering the converter such as HP, gear ratio's, shifting RPM, etc. so that they can build you the right one for your combo. If you purchase a converter too early you will probably need to have it rebuilt when you get sorted out.
#6 | |
#7 | |
I'd say the best T350 , all aluminum, rollerized, low gear set, all the tricks,...would be about equal to a budget built T 200, so you can take it from there..
Liked 1,829 Times in 427 Posts
Don't think so. I should know
james perrone 1290 STK |
The Metric 200 generally cost less than a TH350 if the 350 is anywhere near built right. It sounds like James has experience. I don't. I've always run the Metric. If you want to run reasonably fast, you need to plan on changing to a Metric.
