Liked 55 Times in 26 Posts
What is the most reliable gear for a GM 8.5 at the moment.. Currently have a 4.56 Richmond but heard they have moved everything across the pond.. No one makes a pro gear for an 8.5 so I guess I need the best street gear going right now..
Liked 99 Times in 60 Posts
Fleming,
what is your application and performance level?
Larry Woodfin 471W |
Liked 56 Times in 29 Posts
Motive of Italy bought Richmond, whose tooling was worn out--at least that is what I heard. I have had good results with Motive gears from Italy. A good set will have no more than .002" runout around the ring through several revolutions so each pinion tooth eventually hits each ring tooth.
Liked 56 Times in 27 Posts
Fleming,
What ever you get make sure it is made in the USA !!!! The other stuff won't last 10-15 runs !!! Ask for only USA made , don't waste your Time or Money ??? You can tell by the price if there made in the USA , its always more money.... But well worth it, unless you like changing gears every-week ?? Do it right the first time, its always cheaper in the long-run. Good Luck & be smart ..... Motive, made in Italy/ Germany is an excellent sub for USA made ....
Dave Ribeiro 1033 STK Last edited by Dave Ribeiro; 09-02-2015 at 05:45 PM. |
Fleming,
Strange [and I expect others] sells the U S Gear brand. I have installed several of that brand with good results and good service life. If you want extra insurance you can have the gear set Cryo & REM treated at a cost about equal to the gear set.
Also, considering your application and it's performance range the out of the box gear set will most likely give acceptable service.
Liked 69 Times in 32 Posts
Dewco, they have a multi step process that works
250-300 passes no problem mid 11 second Stocker 3400 lbs
Ron Mattson 5015 STK |
