Old 09-15-2015, 04:03 PM   #1
GregP
Default Stock Elem Crankshafts??
I am aware that there some legal cranks for stock elem for BBC engines that callies makes. but with that being said I see they have some stock type ones as well but are not listed in the NHRA approved listings. can anyone please give me the scoop in regards to if it has to be a exact part number or if they will let a ''stock looking & type slide''? I am in need for a small block chevy 1985 305C.I. Thanks in advance.
GregP is offline   Reply With Quote
Old 09-15-2015, 04:16 PM   #2
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
Default Re: Stock Elem Crankshafts??
It must be listed in the NHRA accepted parts list, according to the rule book. That is the definition of "NHRA accepted". There is nothing listed for a 305. There is a procedure for requesting product acceptance on www.NHRAracer.com.
Old 09-15-2015, 05:14 PM   #3
GregP
Ok so it does actualy have to be listed then, I had just heard from a few engine builders that it was possible to use a forged ''stock type'' and get away with it. even if it wasnt listed as approved.
Old 09-15-2015, 08:41 PM   #4
Greg Reimer 7376
Liked 705 Times in 219 Posts
Cool Re: Stock Elem Crankshafts??
Several years ago, we built a 350 out of a 305 by buying new 350 pistons and a 350 block. We used a 350 piston on 305 rods and used the 305 crank.Since 305 pistons are lighter than 350 pistons, the assembly had to be re-balanced.Most of the weight came off the pistons, and some was added to the crank. If you use a steel 350 crank with Manley or even OEM rods and good 305 pistons, it should balance pretty easily,as the weight will come off the crank only, it's got plenty of weight anyway.It is dimensionally the same as the 305 crank, just heavier, but the balance job will cover that. Sounds like a good way to go!
Old 09-16-2015, 11:02 AM   #5
REGGIE WINKLES
Liked 39 Times in 9 Posts
I use the 1970 LT-1 350 forged crank. It's a bit more weight than the cast 305 crank, but never had a failure or any other concerns.
Reggie Winkles 2650/Stock
REGGIE WINKLES is online now   Reply With Quote
Old 09-16-2015, 11:09 AM   #6
GregP
Thanks for the replies, but can anyone recomend a good aftermarket crank that is legal for a 305 2piece rear seal.
Old 09-16-2015, 11:11 AM   #7
Liked 1,831 Times in 415 Posts
Originally Posted by GregP View Post
Thanks for the replies, but can anyone recomend a good aftermarket crank that is legal?
Yes. Callies. You just have to do the legwork. Or work with an engine builder or supplier who can and will.
Old 09-16-2015, 11:18 AM   #8
GregP
I looked at Callies, they do offer a dragonslayer that would be great, its just not on the approved NHRA list. if there is a trick to this or something please P.M me. I realy wnt to buy the best parts for my engine so I dont have to worry about building a grenade. I used to work for a shop that built comp elem engines, but stock is a total different world from what I am use to.
Old 09-16-2015, 11:48 AM   #9
Rat Raceway
Rat Raceway's Avatar
Liked 35 Times in 17 Posts
Send a message via MSN to Rat Raceway
Not likely you will get the Dragonslayer approved but you should be able to get something nice added to the list. I have had two cranks put on the list. It take a bit of legwork, effort talking to Bruce as well as the people at Callies. Once you have all your ducks in a row it goes pretty fast.
Here is the NHRA form.
http://www.nhra.com/userfiles/file/A...val%20Form.pdf
Ross Gregory
5133 Stock,Super Stock
53 Top Dragster
Rat Raceway is offline   Reply With Quote
Old 09-16-2015, 12:08 PM   #10
GregP
Thanks for the info, I will start looking into this more.
