I have been reading alot about this topic and want to avoid any ground loops if possible. The problem with my car is it still has tons of factory wiring in it so it's a big mess. .
I have a big 0 gauge wire going from BATT- right to the inside fender (wire brushed and bolted, grounding the chassis. I have 2 or 4 gauge wire coming off battery negative going to engine block. Actually I think it is the cam cover but whatever it is, it's the factory spot on the Mustang 5.0. I have a thin strap going from driver side cylinder head to firewall. I don't have a strap on passenger head but the alternator mounting includes block and head on that side so I figure it should be ok. So what do you ground to where? I don't understand when it is best to ground to chassis, engine, cylinder head, or straight to battery negative. And why would it matter if you ground two things to the same chassis ground, rather than grounding them to two different spots on the chassis? They all return through the chassis back to the BATT- |
Liked 269 Times in 99 Posts
With EFI ground reference for each sensor should be relative to it's location due to possible voltage flowing through the ground circuit from leakage of other systems same for data logging sensors they are looking for 0-5 volt input; slight variation can mean a lot..
Bad grounds show up as erratic sensor data also look for electrical noise which can influence wiring not shielded. Shielded wiring should always be grounded to the chassis to battery. Don't depend on engine and chassis bolts without checking with a meter, gaskets and other products can act as an electrical insulator.
Liked 237 Times in 126 Posts
Ground to multiple points just in case one of them gets corroded, loose or whatever.
My 68 Mustang (my avatar) is street legal so it's full of extra wiring. My one wire alternator is grounded directly back to the battery in the trunk with 10 gauge wire. The battery negatives are grounded to tabs welded to the rear angle bars for the cage, one on each side. Over the Winter I'm going to weld tabs to the stock frame in the engine compartment while it's empty and do away with any firewall or fender well ground wires. I have a Painless Performance street strip wiring kit that includes a fuse block for street functions and a switch panel for race functions. I added a Bussman 12 circuit fuse box for all the extra gauges and stuff I have added. This made a rats nest of wiring under my dash so I just now redid it into a consolidated panel on pegboard under an aluminum cover where it's easy to get at. It's grounded to a tab welded to the 6X6 plate that the front of my cage anchors to. It's all buttoned up right now, but I can take the covers off and post photos tomorrow if you want to see how I tried to tame this stuff. Dale
My rear mounted batteries' ground cable goes up to a stud on the rear of the passenger side cylinder head, same stud had all other grounds. Body is grounded directly to the engine as well. Ditto the MSD. No issues.
Ed Wright 4156 SS/JA |
Liked 225 Times in 74 Posts
The computer wires for ground need to go all the way to neg- right to the battery post. When i did this last year to my car it totally change my tune up. I had all ground coming together on a post insulator then a battery cable to the battery, computer was getting noise in that short run from fans and water pump. Bobby what efi are you running.
James Boyce 6052 K/SA Stock National record holder 2015,2018,2 times in 2022,2023 |
#6 | |
Liked 11 Times in 8 Posts
Bobby, don't have a fast system but B+ and B- both need to be directly to the battery for the ECU. Most of the systems I've seen as far as sensors go the ECU has discreet circuits for them ( the reference, low reference (ground) and signal all go back to the ECU, then use the main ECU ground which should be hooked directly to the battery. Most agree that any other inputs....O2's input signals (cam sync, crank sensor if it's a hall effect ) should share the ground that the ECU uses to eliminate ground offsets. All other things Alt. electric water pumps, fans ect. can be chassis grounded provided the engine AND chassis are properly grounded. I like to run a ground between cylinder heads and to chassis just to provide a solid ground path. To me the bottom line is to try and keep EFI componemts grounds seperated from everything else...by grounding the ECU directly to the battery you do just that.
Joe Buchanan SS/BX 3117 |
Liked 1,034 Times in 368 Posts
Don't go directly to battery on the positive side if your running 16 volt battery's . You will have to connect to kill switch, so you are not charging your ECU and MSD during charging . They charge at 20 volts ,and I found out the hard way it will pretty much damage everything in your car ......
Jeff Niceswanger 3740 SS |
Remember any module or ecu needs to have electronic power and ground. That means power and ground must come from the battery directly. You can run electronic power and ground studs in the engine bay just run cables to them from the battery. (if truck mounted).
Liked 6 Times in 4 Posts
Dale Shearon..... Would love to see pic's of what you did...........
