Liked 79 Times in 11 Posts
here we go. 89 mustang 5.0 stocker. changed from the stock tank and lines to a fuel cell and an external pump. starts breaking up at 4500 ever since. the only thing I haven't replaced is the mass air flow meter and the cell. it's an 4 gallon aluminum cell. no foam. --10 line from tank to the pump. -8 line up and back. I change over to a 4bbl intake and carb and it runs great. any ideas. i'm to the point where i'm ready to put the stock tank back in.
bob beals 7244 |
Check fuel delivery first. Line out of regulator into a jug, how long to pump a gallon?
Make sure return is not putting air into pickup area? Good voltage to pump at RPM? Once you are sure you are getting fuel into carb, then start down other paths. Good luck. Ken Stock 412 |
Liked 101 Times in 52 Posts
This came with injection correct?
It breaks up with the injection but runs OK with the carb may be that it is running out of fuel. What is the pressure? Had the mass airflow sensor fail on my Buick and it would be ok under light throttle but was lost accelerating under load. It was fine one day and bad the next. At first I thought it was the gas I'd purchased but quickly discovered new fuel wasn't the answer. I'd think fuel first as Ken said. Does it break up even in neutral? I'm sure the other guys here know way more on this than me and can assist. My niece had a Mustang Cobra but it has been a few years since that was sold. |
Liked 799 Times in 236 Posts
The fuel returning to the tank can really aerate the fuel in the tank if you just let it dump back in. Try extending the tanks return fitting so the returning fuel is submegered....like a pick up tube in reverse.
"That'll never work....." Last edited by Alan Nyhus; 11-21-2015 at 09:04 AM. |
Just for grins, check your high end chip. I've seen this happen twice in recent years.
Liked 1,955 Times in 590 Posts
Doesn't fuel injection take a higher pressure pump than a carb car or is there just a difference in the regulator. I was under the impression that fuel injection needs a lot more pressure than a carb
Mike Pearson 2485 SS |
Liked 254 Times in 78 Posts
Agree - injectors need a lot more fuel pressure to work properly, and it needs to stay high under load.
Mike Moller NHRA 203 Q-R-T/SA Last edited by MikeMoller; 10-21-2015 at 11:47 AM. |
Liked 372 Times in 130 Posts
40 psi for efi vs. 7 for carb.
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT |
#9 | |
Liked 11 Times in 8 Posts
Joe Buchanan SS/BX 3117 |
Liked 227 Times in 74 Posts
Are you changing pump setups between the 2 systems? Your pump my not be putting out enough flow at the higher pressure 40 and above, but put enough flow at 7 psi for a carb. I have run as fast as 11.60 with all the stock fuel lines in my car with just one size up pump. This is also a 5.0 mustang.
James Boyce 6052 K/SA Stock National record holder 2015,2018,2 times in 2022,2023 |
