Old 11-01-2015, 07:56 AM   #11
GregP
Default Re: New Approved 305 Stock/Superstock Block..
I have noticed some of you have sent me P.M's in regards to the 305 &350 block. for some reason this site is not allowing me to respond to your private message. if you can please send send it to my personnel email. gregporcello@yahoo.com
GregP is offline   Reply With Quote
Old 11-01-2015, 10:15 PM   #12
Todd Boyer
Liked 6 Times in 5 Posts
GregP, have you let the site admins know about the PM issue? Sounds like a website glitch to me.
Old 11-01-2015, 10:19 PM   #13
GregP
Not yet, but thanks for reminding me. I'll try that.
Old 11-01-2015, 11:13 PM   #14
FED 387
Liked 333 Times in 180 Posts
wonderful product for those that need to take advantage of it!!! however for those that can do the work themselves and do not need to take advantage of this block its still a pricey item--FED 387
Old 11-02-2015, 10:13 PM   #15
GregP
Yes it is pricey, but as I mentioned they sale the same one but for a 350 and I still have to install the sleeves. this will have performance pros and cheaper labor wise for self use or resale.
Old 11-02-2015, 10:59 PM   #16
MR DERBY CITY
Liked 8,106 Times in 1,531 Posts
Mr. FED , I am not sure if you are aware of this but, there are not many ...if any, good 305 production blocks in existence.GM does not manufacture any more Bow Tie small bore blocks so....that is not an option. A racer could sleeve a 307 small block Chevy ,but sleeves are not always the best way to go and sometimes come with their own problems. As stated earlier,Greg P......GOOD JOB.....from ALL the 305 guys.......M.J.
Old 11-03-2015, 01:17 AM   #17
Liked 1,883 Times in 423 Posts
Yep, you can easily run well over $1,000 putting 8 flanged sleeves in a block, before you do anything else. And I won't waste time with anything but flanged sleeves in a race engine, they solve the vast majority of sleeve problems, once installed correctly, they'll outlive the block and be trouble free.
So, go buy a block, $100, plus your time hunting it down, assuming you only have to buy one to get a good one. Hot tank and inspection, another $100. Align hone, $150. Index the lifter bores, plus bushings, $450. Square the deck, and set deck height to spec $300. Install 8 flanged sleeves (sleeves $100+ each) and bore true, $450. That aftermarket block is starting to look real nice for anything under $2200.
Old 11-03-2015, 10:01 AM   #18
GregP
Alan, thanks for explaining it Like that as well,lol. People look at the initial cost and think that's high, but after all the machine work and hoping you got a good one to begin with,well let's just say it's a heck of a lot easier to order it ,bore to the needed cylinder size , then hone to finish and be done,lol
Old 11-04-2015, 10:22 AM   #19
rod butcher
Liked 132 Times in 27 Posts
MJ is correct. The other option is to fill a 305 block, but that wouldn't be my first choice. I am not a big fan of a sleeved block, either. If I were building a new piece my first choice is a small bore bow-tie and my second choice would be the dart 305. My reasoning is the bow-tie has a thicker cyl. wall than the dart block.
rod butcher is offline   Reply With Quote
Old 11-04-2015, 12:16 PM   #20
Jody Lang
Liked 92 Times in 29 Posts
FYI
Just know that the Dart block is approx 50+ lbs heavier than a stock block.
Jody Lang is offline   Reply With Quote
