Liked 15 Times in 2 Posts
This time of year I get a lot of calls from guys looking at a data recorder for the first time and they have a lot of questions on the V-net concept.
Essentially, it's a network which allows a single cable to go from the engine bay to the recorder. Some data systems require wires from every sensor to go all the way back to the logger. Pro Stock cars have 20-30 sensors on them (even more when testing). A typical layout below: ![]() Key points: - The cable running from the recorder to the first sensor is typically 9' long if the recorder is mounted behind the passenger seat. - The wires from the V-net module to the sensor plug are 48" for pressures and 72" for Temperatures. - Although not recommended, those cables can be shortened/lengthened. - There is a bulkhead connector available to go thru the fire wall. - Racers tend to say "I need a oil pressure sensor" and they mean a V-net module + the physical sensor. - To add a sensor pop off the cap and snap the next V-net module on. - Keep data logger wires away from plug/coil wires and the coil primary wires (MSD Orange/Black going from the 7AL to the coil) Post up any questions you may have. Greg Kelley 609-265-2110 gkelley@MotorSportsInnovations.com Sponsor of: - East Cost Stock SS Association - Mid Atlantic Super Gas SC Association - Indy Fast & Old - |
Liked 16 Times in 5 Posts
Can the tach pickup be spliced into the existing MSD tach output? (6AL)
#3 | |
Yes Bob - that's exactly how you pick up tach signal from any of the MSD boxes. |
Should have been more specific---------- The existing Autometer tach is on the same wire as the Racepak is that OK?
Correct.
Liked 1,958 Times in 593 Posts
I would like to upgrade to a system like this. Do you ever have any factory reconditioned units available for a reduced price. A new one is not in the budget right now. What is best for a super stock car? Carbureted combo.
Mike Pearson 2485 SS |
No Used/refurbed Sportsman kits right now Mike.
For a SS car I would recommend the Sportsman kit with an O2 sensor possibly a fuel pressure (about $1350 for everything). If you are a clutch car then also a input shaft sensor. |
Thanks for the reply. I will be in touch when the time comes.
