Old 11-16-2015, 08:48 PM   #1
55 zimm
Default Phoenix FX tires on a heavy stick car
I would like some input on Phoenix fx tire on a heavy (3500#) stick car. I currently run M/T 10.5 w x 29.5 or 11.50 x29.5 with good results for approx 50 passes then they start to get inconsistent. I was thinking about trying the Phoenix FX tires, I know many super stock guys used the firestones years ago. Any input would be great
Thanks
Dirk Zimmerman
55 zimm is offline   Reply With Quote
Old 11-16-2015, 09:50 PM   #2
BLIND MULE
BLIND MULE's Avatar
Default Re: Phoenix FX tires on a heavy stick car
Try to get in touch with Mike Crutchfield or maybe he will see this and give you some advice he is a Phoenix dealer!
BLIND MULE is offline   Reply With Quote
Old 11-17-2015, 07:17 AM   #3
james schaechter
Liked 1,439 Times in 301 Posts
Are you running tubes? If not, that would help.
Thanks
Dirk Zimmerman
James Schaechter 3163 STK
Old 11-17-2015, 08:16 AM   #4
terry1
Liked 24 Times in 13 Posts
Smile Re: Phoenix FX tires on a heavy stick car
I hope I'm not hi-jacking this thread but, is there anything, other than baby power, to help with the tube not folding over or twisting during the slick install?
Terry K
terry1 is offline   Reply With Quote
Old 11-17-2015, 11:02 AM   #5
Dan Timberlake
Terry K
Starting with a partially inflated tube, and finishing with A couple of inflate-deflate cycles helps on dirt bike tires.
Dan Timberlake is offline   Reply With Quote
Old 11-17-2015, 12:50 PM   #6
55 zimm
I do run tubes in the M/T tires I have tried them tubeless with no change in ET for me and they leak bad even with all the tricks (soap etc.).
Baby powder has worked the best for me when mounting. I tried silicon lube once that was a bad idea.
Thanks Dirk
Old 11-17-2015, 01:09 PM   #7
Mike Pearson
Mike Pearson's Avatar
Liked 1,945 Times in 586 Posts
Try some Hoosiers. They seem to last longer and more consistent longer than the M/T tire I was using. There is not many class racers running the phoenix tire these days. Mike Crutchfield is the man when it comes to Phoenix tires. Let me know if you need his e mail address.
Mike Pearson 2485 SS
Old 11-17-2015, 01:58 PM   #8
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Thanks Dirk
YUP my M/T's leaked too !
For a while would wheel hope doing a fast burnout.
So did a slow one until hot.
Could raise rpm after 20 burnouts.
D
Old 11-17-2015, 02:11 PM   #9
Ed Wright
Ed Wright's Avatar
Never mind. Sorry.
Ed Wright 4156 SS/JA
Old 11-19-2015, 09:12 AM   #10
55 zimm
Thanks for the input. I Have a little time this long cold Illinois winter to figure things out.
Dirk
