Old 12-04-2015, 01:34 PM   #21
Grey Ghost
Grey Ghost's Avatar
Liked 210 Times in 88 Posts
Default Re: 3sp to 4sp manual
I want to update from the Mopar electronic race ignition to an MSD. What is the difference between the 6AL and the 6AL-2. Both have 2 step and listed output is simular. Both are suppose to work with the Mopar distributor. Anyone have a preference.
Grey Ghost is offline   Reply With Quote
Old 12-04-2015, 04:29 PM   #22
Stephen & Horace Johnson
Liked 163 Times in 53 Posts
Originally Posted by Grey Ghost View Post
Thanks Sean.
I have a 2 piece Lakewood that NHRA accepted when I was running the Dodge. Do they still accept 2 piece bellhousings? Also have aluminum and steel flywheels in various weights and diameters. Is Advanced Clutches 10 1/2" clutch a good piece?
Does anyone know if Bob Sharp is still racing his A/S Camero?
Bob has a A/S 427 fairlane
Stephen Johnson #2162
Horace Johnson #2167
Stephen & Horace Johnson is offline   Reply With Quote
Old 12-04-2015, 06:22 PM   #23
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Thanks Sean.
As long as the bellhousing is SFI certified. Or can be recertified, then you might be able to use what you have. The bellhousings without windows has to be recertified every 5 years. The ones with a window every 2 years. Lakewood had bellhousings that used I believe 3/8" bolts and those will not recertify. It was a money ploy to make people buy new bellhousings this would have been around 1998 to 2004, so you may need to look into that before spending money on shipping only to find out that the shipping company made money and you have to buy a new bellhousing.
The dual 7" clutch is the wiz bang clutch and the tuning window is really wide. That is what I run, but there is nothing wrong with the 10" clutch that Advanced has. Whatever you do, get a clutch that is setup with low base pressure. Otherwise it's a parts killer, or a compromise to getting launch and high gear dialed in with the clutch tune.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 12-05-2015, 09:39 AM   #24
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Bob had a 427 Fairlane. He sold it and built a '67 Camaro 396-375 now converted to a '68. Did he sell his Fairlane to the west coast boys?
Old 12-05-2015, 10:07 AM   #25
4284spd
4284spd's Avatar
Bob Sharp sold the first one to Robert Pond. Then the Camaro and now he is back in another 427 Fairlane.
Bob Smith
Old 12-05-2015, 10:33 AM   #26
4284spd
4284spd's Avatar
Bob Smith
Old 12-05-2015, 05:16 PM   #27
Bunkster
Liked 43 Times in 10 Posts
Originally Posted by Ed Fernandez View Post
Hey bunkster go back under the rock you came out from under.It's none of your business what name anyone here uses. Mr Gould doesn't have a copyright on the name of his car. The OP said he's been away from racing 20 years ago. He's no nubie.
Go over to Yellow Bullet if you want to rub it in peoples butts. You started it in the deep staging thread now you're doing it here.
Kenny if I'm wrong tell me so.
My goodness, you have my apologies. I didn’t mean to offend you.
Usually, someone with your level of vitriol has a problem with alcohol. Here’s a group that might help you:
http://www.aa.org/
Bunkster is offline   Reply With Quote
Old 12-06-2015, 12:33 AM   #28
Ed Fernandez
Ed Fernandez's Avatar
Liked 100 Times in 45 Posts
http://www.aa.org/
You didn't insult me pea brain you were rude to a new poster before you knew anything about him. I do not and never have had an alcohol problem but your posting history does show you have an abundant lack of brain cells.
Former NHRA #1945
Former IHRA #1945
T/SA
Old 12-07-2015, 09:35 AM   #29
Robert Simpson
Liked 20 Times in 12 Posts
Originally Posted by james schaechter View Post
Robert, I looked and do not see this in the rule book. Help me out and tell me where it is? I would think the three speed stick to four speed stick would be in alignment with the two speed to three speed auto accommodation.
James it appears that I owe a appology concerning the 4sp in stock. I really thought that I read it in the updates but I do not see it in the rule book at all. I believe that this would be rather easy to update with NHRA since the auto trans rule is very similar between S and SS, I am refering to the number of forward gears.
Thanks
Robert
Robert Simpson is offline   Reply With Quote
Old 12-07-2015, 12:22 PM   #30
Originally Posted by Robert Simpson View Post
Yes you can replace the 3sp manual with a 4sp manual in stock along with SS. So if you have a 265, 6Cyl comet or 6Cyl Nova you can run a 4 speed. Also for PG optioned stockers and SS can run three speed autos. The above mentioned combo's were just examples. Hope this helps.
Robert
This not correct then?
Someone from a concerned party needs to ask why not.
