Old 12-30-2015, 12:07 PM   #1
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Default WaterWetter Products
Do these water wetter products work?
Or is it hype?
Dan
Old 12-30-2015, 12:56 PM   #2
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Default Re: WaterWetter Products
I can't tell you in terms of degrees, but I know how these things work so I'll do that.
I have a degree in Photography from the film days and we used a product called PhotoFlow - a "water wetter" - when developing film. It breaks down the surface tension of water used for the final rinse of film and causes it to sheet off without sticking to the emulsion and leaving spots. In an automotive application it would increase the slick flow of fluid through the engine and prevent it from clinging to surfaces. By not clinging, it should increase it's ability to carry off heat.
Disclaimer: I use the stuff. I put zinc additive in my regular oil, too.
Dale
Dale Shearon
68 Mustang 6394
Old 12-30-2015, 01:12 PM   #3
stage1scott
stage1scott's Avatar
Liked 109 Times in 44 Posts
on a couple of my higher compression Buick 455s (years ago) Water Wetter was good for a solid 10 degrees decrease in summer driving temps in SoCal, as seen on a mechanical temp gauge.
Old 12-30-2015, 03:59 PM   #4
Jim Kaekel
Liked 536 Times in 110 Posts
Years ago when I towed with a Ford F250, it helped it to run a little bit cooler while pulling, probably 5-10 degrees.
Jim Kaekel 3836 STK
Old 12-30-2015, 04:06 PM   #5
Dan Fahey
Dan Fahey's Avatar
Dale
WOW I remember that too.
Use to work in the Physics Department in College.
Took many B&W and Color Photos and Developed them.
Sometimes wrote reports detailing findings.
Now an art for old school Photographers and Restorers.
D
Old 12-30-2015, 05:40 PM   #6
FireSale
FireSale's Avatar
D
I always thought that if you scratched a hot rodder you'd find a scientist or engineer.
Dale
Dale Shearon
68 Mustang 6394
Old 12-30-2015, 06:13 PM   #7
Greenlight
Liked 81 Times in 23 Posts
This seems like an unbiased test:
http://www.superstreetonline.com/how...tem-additives/
I know several guys that SCCA race that have nothing but good things to say about it, unless someone blows and engine and it leaks on the track. Apparently, the silicon in it is bad for traction. Who would have guessed?
Greenlight is offline   Reply With Quote
Old 12-30-2015, 06:17 PM   #8
Eman
Liked 133 Times in 76 Posts
I use the Lucas coolant additive with bottled drinking water. I bracket race so it's a once a year deal. If I was class racing and dropping the water to cool the block I wouldn't bother with anything more than tap water.
Eman is online now   Reply With Quote
Old 12-30-2015, 06:39 PM   #9
Dan Fahey
Dan Fahey's Avatar
Most Spring Bottle water has more sediment in it than Tap Water.
Use to do water test and experiments with a centrifuge.
FWIW at one time the best tasting water on the East Coast was NYC Water.
Big surprise not sure what it is today but usually on top.
Chateau de Potomac came close to best tasting tap water in USA.
Have seen distilled water being sold.
Need to learn where I found it.
D
Old 12-30-2015, 07:29 PM   #10
bob shirley
props for water wetter, have been using it for years in four cars, it works
bob shirley is offline   Reply With Quote
