Old 01-01-2016, 08:48 AM   #11
gbur
Default Re: 3rd gen camaro rearend
Originally Posted by mike britt View Post
How strong is the 7.5 rear end? will it stand up to a 305? The lowest gear I can find for it is a 4.56, not sure if that'll be enough.
you won't find more than 4.56, wish there were
Gary Burr IHRA MEMBER # 1958 Stk 1949
gbur is offline   Reply With Quote
Old 01-01-2016, 11:25 AM   #12
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Remember a Camaro/Firebird LT1 shoot out at Englishtown mid 90s.
Had a bolt on class, cam only, head cam, stroker heads up classes.
All still using the 7.5 rear and making it last.
Got old magazine issues that showed how they made them work.
Today you can get a complete Moser 12 bolt.
With heavy duty brand new everything for about $2000.
It is a good long term investment for a dedicated race car.
D
Old 01-01-2016, 11:29 AM   #13
impstocker
impstocker's Avatar
Liked 53 Times in 16 Posts
Because the Dana 44 came in 83-86 Camaro's I could use one in the 85 camaro i will be starting? Correct?
Will Lamprecht
1965 I/sA Impala
85 Camaro W/SA TBI L4 possible
Old 01-01-2016, 11:47 AM   #14
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
Yes, but finding one will be a chore. AFAIK none were installed assembly line. They were sold OTC and will be very rare.
Old 01-01-2016, 12:23 PM   #15
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
I think the Aussie built , Dana 44 were only found in Pontiac Formula's and Trans Am's . Camaro's used the 7.5 which was later upgraded to a 7 5/8 . At the junkyard, you would be wasting your time looking under a Camaro. There was one on Detroit Craigslist just last week, so you should be able to find one .
Old 01-01-2016, 03:05 PM   #16
brian schuetta
Liked 28 Times in 15 Posts
The 9 bolt came in 5.7 Formula Firebirds for sure ,got one on the driveway. By time I got my 305 running in my 83' Camaro it had a 2.75 low gear trans, 5.13 gears, and a 5200 stall converter. If you think you can throw that, and slicks, at a 7.5 and not worry about it about it I would say you are fooling yourself. And that engine dyno'd at 345 hp, there's a good chance you will make more. Go with the Chevelle 12-bolt if you don't have the money for a complete Moser, you won't find the gear you want with a 9 bolt. I might still go to the Moser in my car. Build the suspension in the car solid, you might want to do something different with it later as life situations and locations change. I got a 385 Vortec head SBC in mine now and bracket race it.
brian schuetta is offline   Reply With Quote
Old 01-01-2016, 03:12 PM   #17
brian schuetta
Now the 9 bolt or 7.5 might hold up to a L4, but I don't know what's needed to get one moving. The L4 Camaros were real dogs, maybe got good mileage though.
Old 01-01-2016, 03:26 PM   #18
russellauto1
Liked 35 Times in 6 Posts
I run C/ps and use 7 5/8 rear end. Made it 75 passes at 1.60 60 ft times on stock posi with 4.56 gears, jegs axles, rear support cover, a quality gear. Broke Posi Gears. Then put in a Detroit tru trac and have put 45 more passes on it with 60s in the 1.55. Run 12.40s in qtr. 7 5/8 has less drag then a 12 bolt or equal. Lots of guys are going low 11s with an auto.
This is on 3rd gen.org under drivetrain parts
In Illinois
http://cimg5.ibsrv.net/gimg/www.thir...0ea4d5e50a.jpg
I have a Dana 44 rear 3:92 gears fresh built posi unit ,new clutches new set of stock axles ..
new wheel bearings
has lower control arm relocation brackets installed , chrome cover
I am considering selling it or trading it locally will not ship .. trying to Gauge interest
$ 1550.. or better I do not NEED to sell it don't bother low-balling me not going to happen
I also have a new set of DANA 44 4:56 gears with install kit and gaskets $200 or best offer
if can not sell it here it goes ebay ...
russellauto1 is offline   Reply With Quote
Old 01-01-2016, 04:35 PM   #19
mike britt
Liked 66 Times in 31 Posts
I'm not sure how to tell which rear is in this car, 7.5 or 7 5/8. I'm thinking about bracing the housing, putting a gear in it, c-clip eliminators, and a girdle cover and running it. If money was no object I'd go with the strange 12 bolt housing, which it might come to later.
mike britt is offline   Reply With Quote
Old 01-01-2016, 05:24 PM   #20
Terry Witzel
Terry Witzel's Avatar
Liked 50 Times in 28 Posts
I ran my Camaro for several years with a completely stock 7.5 running low 14's. When I got to mid 13's I upgraded to a auburn posi and Richmond gears and then broke the rear end in no time. I would just get a 12 bolt.
