Liked 319 Times in 108 Posts
I usually prime engine with drill to see how rockers are oiling and go from there,some darts take restrictors in front and rear, most restrictors you buy have .030''or .060'' hole in them.
If they was to not oil at oil you will need to pull lifters out and cut small groove from oil band to oil hole on lifter body, only need few thousands deep, I use mini die grinder or thinnest cut off wheel can get,may take a try or two to get oil flow you want. Mike Taylor 3601 |
With my Bowtie block and Isky Red Zone lifters, I had to do what Mike mentioned above here, to stop burning the top ends off my intake pushrods. Thanks Gary Hetler for that tip! I used a small 3 sided file. No restrictors. No more push Rod problems.
Having somebody like Mike Taylor help people here is great.
Ed Wright 4156 SS/JA |
#4 | |
Liked 18 Times in 10 Posts
Have your lifters been fit to the bores ?? This sometimes is over looked. What lifters are you using? |
i am using comp cams longer lifters--they are for the dart block. i'm about to assemble it and i want to be right on the upper end oiling ---it is a drag car thanks
Liked 13 Times in 11 Posts
I'm assembling my little M sportsman now and after some thought decided to NOT restrict. Roller.
In fact , I'm not cutting the small groove in the lifters either. It'll probably move more than enough oil as is. |
#7 | |
Hopefully those are not the elite lifters as I was told they were discontinued. Check the lifter bores for size against your lifters....... I don't let any block out the door with out fitting lifters to the bores. If you want to run a roller lifter that is to OEM size the Morel lifter are about the only ones out there. |
Like Carl said whatever brand you use be careful,like I said before I always check oil flow by priming with drill,no matter if is new combination,one I am just freshening up,it can save you alot of headaches,what you take for granted will be what bites you.
Thank's Ed for the kind words,I try to help if I can,most of it I have learned the hard way.LOL Mike Taylor 3601 |
#9 | |
On ISKY lifter I have found sizing issues along with other builders out there, Every time I have had a customer send me those lifter I have had to get 2 sets to make up one set on one occasion it took 3 sets. Here is just one page of many. http://www.yellowbullet.com/forum/sh...1631930&page=5 |
#10 | |
