Old 01-18-2016, 10:09 PM   #41
George Wright
George Wright's Avatar
Liked 408 Times in 35 Posts
Default Re: Lapping piston rings
I had this tool made up about 25 years ago. It is for a 4.060 bore. On one side there is a dish cut in it that allows you to hold a ring inside of it. The ridge is about .025 tall so that the ring is exposed. I can then use this fixture to sand down the ring on a piece of fine paper taped to a piece of glass. The other side of this ring fixture is used for squaring rings in bores when checking / setting the ring end gaps.
ID:	32250   Click image for larger version
George Wright https://9500rpm.com
George Wright is offline   Reply With Quote
Old 01-18-2016, 10:58 PM   #42
Liked 1,889 Times in 423 Posts
Alan
Who do you talk to at JE. I need to get 2 pistons to replace 2 that were damaged
Thanks,
There is now a new guy at JE running the Stock and Super Stock program, his name is Allen. I have not dealt with him as of yet, but plan to talk to him in the next 2-3 weeks.
Old 01-19-2016, 08:39 AM   #43
Liked 10,836 Times in 2,252 Posts
George when you put a taper face ring into the fixture does it want to cup the ring up, away from the land when in compression?
Thanks Larry
Old 01-19-2016, 08:49 AM   #44
Adger Smith
Liked 880 Times in 311 Posts
This is how a friend of mine back cuts rings to decrease tension.
ID:	32252   Click image for larger version
ID:	32253   Click image for larger version
Adger Smith (Former SS)
Old 01-19-2016, 09:30 AM   #45
Ed Wright
Ed Wright's Avatar
Mine look just like that, but a little deeper. .035" for the old .043" rings I was using.
And, no the rings stayed in place just fine.
Lap one side flat, flip them over and lap the other side flat. Mic the ring, and if needed, touch up the thickness.
Ed Wright 4156 SS/JA
Old 01-19-2016, 02:32 PM   #46
George Wright
Thanks Larry
I was not using tapered rings.
Old 01-19-2016, 07:53 PM   #47
Ed Wright
Ed Wright's Avatar
Thanks Larry
Larry, the top rings I have used were all barrel faced. Had tapered second rings. Never lapped those.
Old 01-24-2016, 03:28 PM   #48
JHeath
JHeath's Avatar
Liked 370 Times in 101 Posts
Finally figured out a way to post the article...
Jerry Heath
I/S '93 Cobra
FS/J 2010 Mustang "Ebay CJ"
Old 01-25-2016, 02:54 PM   #49
GTOMayhem
Liked 22 Times in 14 Posts
Thanks Jerry!
Rick Thomason
GTOMayhem
GTOMayhem is offline   Reply With Quote
Old 01-25-2016, 06:09 PM   #50
joe cool
Liked 5 Times in 3 Posts
Ok fellas ,I'm a dummy ,I just read a lot trying to understand. If you actually increase the thickness of the rings doesn't that allow compression to leak behind them.? Thanks
Joe Keightley
Pacific Junction Iowa
joe cool is offline   Reply With Quote
