Liked 85 Times in 22 Posts
I'm looking for suggestions on shift improver kits for a turbo 350. This is not a race car so not interested in a full manual and teeth rattling shifts on part throttle shifting but firm to hard shifts at full throttle would be the ticket. Thanks Doug
Liked 71 Times in 38 Posts
I've used both B&M and TransGo at different times.Either one seemed to work equally well.If you don't want neck snapping shifts,leave the 1-2 accumulator spring in place or replace it with one from the kit.
Superior, or Fairbanks. Been using them for 30 years.
Alan Roehrich 212A G/S |
I would also recommend the Trans go shift kit. The instructions are well written and it is easy to install. The kit also has different stages to taylor to your needs. You can buy on Ebay or any transmission parts distributor.
Liked 133 Times in 76 Posts
Transgo hands down. I've used B&M and Transgo and the Transgo is better. It doesn't slam into reverse or shift gears hard. B&M is much more aggressive.
Liked 166 Times in 71 Posts
Transgo, no other way to do it right.
Chris Chapman 1969 Chevelle NHRA F-G/SA 1090 |
Liked 81 Times in 23 Posts
Just drill the valve body spacer plate as shown in the image about 3/4 the way down the page in the link shown below.
http://www.crankshaftcoalition.com/w...0_rebuild_tech |
