Liked 68 Times in 26 Posts
hi, I see how MSD wires their relay 8961 into two step and clutch switch.
how does it switch from high side to low side?? the instructions in book doesn't tell you anything . I tried calling all three numbers, and no answer. do you have to install a switch , to select high side and low side ? just curious, as going to install the relay in a clutch car. like to know before hand. thanks |
Liked 507 Times in 116 Posts
68 Chevy11 327 F/S |
Liked 129 Times in 59 Posts
The red wire from the two step, connected to and energized by the 8961 Relay controls the high/low function when used with a clutch switch.
http://www.jegs.com/InstallationInst...1/121-8961.pdf (See Figure #6) Hope this helps!
Lew Silverman #2070 "The Wagon Master" N/SA |
Liked 1,943 Times in 584 Posts
The high side on the 2 step is always active. The low side is activated when power is applied via a switch.
Mike Pearson 2485 SS |
hi, ok, if the line lock sets the low rpm, how do you do a burnout? won't have enough rpm to spin tires, prob slip clutch? I do my burnouts on high side, then switch to low side for launch now. I want to use their relay and rewire my system.
Liked 320 Times in 102 Posts
I think that if you want to control leave, burn out and high side rpm you would need a 3 step......or a switch to turn off 12 volts to the 2 step module with the line lock energized for your burn out
If you put in a switch there will be no RPM limiter for the burn out... Bob PS: Remember to turn the switch back on after burn out!!!!!!!!!!! Are you running an automatic or stick???????????????????????????//
Bob Mulry 7516 STK A & M Motorsports Last edited by Bob Mulry; 05-03-2016 at 05:47 PM. |
I may have missed something here, but aren't you using the line-lock/low-side limiter for your burn-out's?
If you need a burn-out, launch AND over-rev protection, you'll need to follow Bob's advice and get a 3-step switch to work with your MSD and relay (although unless you'll be controlling a high-amperage circuit, you may not need one). MSD has all of their wiring schematics, cross referenced by unit number, on their website, as well as a very handy smartphone app, to help if you need it.
Liked 293 Times in 65 Posts
I just use my right foot to control burnout RPM...seems a whole lot simpler and less stressful on the engine.
Then the switch on the clutch pedal runs the low side limiter. |
Liked 805 Times in 245 Posts
Jim, I understand your point about wiring the line lock and low RPM two step together being a problem for burnouts but if the RPM is too low for clutch lockup wouldn't the simplest solution be to just add another inline switch to override the two step during burnouts only? Just switch it back on after the burnout?
Liked 333 Times in 180 Posts
Why not use a 3 step. Burnout/launch /top end MSD # 8737 about $100 I have a new one sell it for $60 plus mail. Fed387
