Old 05-20-2016, 09:30 PM   #11
james schaechter
Default Re: Best lifter?
We have been using the trend limited travel tool steel lifters that we get from Alan Roerich. We then send them to dynacron to get treated. We run 200 seat and over 400 open on nitrided cast cams with hundreds of runs. No issues.
James Schaechter 3163 STK
Old 05-20-2016, 09:45 PM   #12
ron mattson
Liked 69 Times in 32 Posts
Cast nitrided with Dynacron coating on cam and
Lifters works awesome, ran 2 yrs and cam looks
Perfect.
Ron Mattson 5015 STK
ron mattson is offline   Reply With Quote
Old 05-21-2016, 08:17 AM   #13
Alan Nyhus
Liked 800 Times in 237 Posts
James and Ron, a couple of questions:
- Are you having the cast cams nitrided and then Dynacron coated?
- Is a non-Dynacroned, nitrided cam is okay?
- If you're going to Dynacron the cam, do you get a non-nitrided cam to start with?
- What are you doing for break in?
Feel free to PM me if you wish. Thanks in advance for the advice! -Al
"That'll never work....."
Old 05-21-2016, 06:51 PM   #14
tuffxf
Liked 11 Times in 5 Posts
Gday,
Very interested in the reply to the above question if you dont mind sharing, also any issue's with different oils or additives affecting the coatings?
Cheers
Paul
tuffxf is offline   Reply With Quote
Old 05-21-2016, 09:56 PM   #15
ron mattson
I have been nitriding the cam and having it
And the lifters both Dynacron coated. Have
Used all types of oil with no issues. I have been
Breaking in with soft springs also!
Old 05-22-2016, 04:53 AM   #16
tuffxf
Gday Ron,
Thanks for the response!
Cheers
Paul
Old 05-22-2016, 08:15 PM   #17
I thought I got you guys a set or two of solids as well. Not sure if that is correct, or where they went, maybe in the 396 in the Corvette.
By the way, if anyone is concerned about oil flow to the top being too much, they have a pushrod cup with a 0.014" orifice. They can probably be added when ordering at a low or no cost upgrade.
Several DLC coating applicators say they do not like the Driven oil, and will not offer support to those using it. I do not know the story behind that, other than a few years ago, there were some lifters that the coating came off of in NASCAR engines. The Cup guys use less spring pressure than most Stock Eliminator guys use. No DLC coating applicator I know of will suggest or support their coating applied to a lifter being run on a cast iron cam core. I have had some tell me to coat the cast iron cam and the lifter, but I have not tried it, nor do I intend to.
Old 05-23-2016, 04:56 AM   #18
james schaechter
Yes we had solids for the 396 as well.
Old 05-23-2016, 09:24 AM   #19
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 317 Times in 108 Posts
Robert,
I haven't used any coatings,use the P-55 cores,non- nitrided,PPPC lifters uncoated.
Use lucas break in oil and race oil.
Have switched them and broke them in to another cam,check the crown on the bottom of lifter if has .0012'' or more and smooth use again.
Mike Taylor 3601
Old 05-23-2016, 11:32 AM   #20
ron mattson
Dynacron is not a dlc it is a tungsten disulfide
Lubricant coating and has a natural affinity or
Attraction to any oil, kinda has a property to keep
Oil on the surface making it a double benefit.
