Liked 46 Times in 20 Posts
What is the difference between a 520 head and a 520 T head.Is it worth finding a 520 T head if I have a set of 520 heads?
Liked 8,116 Times in 1,531 Posts
The T, no....
Liked 783 Times in 195 Posts
Depends on what you have. As a general rule, the later heads are better than the early heads. But the T is not necessary. It's just that the T heads are all late production heads.
To answer your question seriously, if the heads are to be , shall we say chemically enhanced....then you will be fine with either head or even an 896 casting.
Liked 99 Times in 49 Posts
Dwight if you where to build a 283 stick car what would a starting trans and end ratio would you chose. Jim
Jim, you have a PM.
