Old 06-15-2016, 03:00 PM   #1
my69396
Liked 46 Times in 20 Posts
Default H/P to weight question
Is there a formula for weight to horsepower? How much h/p would a 283 have to make to run high 12s in a 3300 lb car?
my69396 is online now   Reply With Quote
Old 06-15-2016, 04:03 PM   #2
Mike Pearson
Mike Pearson's Avatar
Liked 1,937 Times in 582 Posts
Default Re: H/P to weight question
If you plug those numbers into the Wallace power speed calculator you will need about 320 HP to run 12.80 at that weight.
Mike Pearson 2485 SS
Old 06-15-2016, 05:45 PM   #3
ALMACK
ALMACK's Avatar
Liked 369 Times in 127 Posts
http://www.wallaceracing.com/et-hp-mph.php
Scroll down and pick you formula
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 06-15-2016, 05:55 PM   #4
ALMACK
ALMACK's Avatar
12.90 @ 3300 lbs = 304 hp
Not sure if that is 304 rear wheel or flywheel hp
I/PS '95 Mustang GT
Old 06-15-2016, 06:01 PM   #5
Ed Wright
Ed Wright's Avatar
304 at the tires will easily run 12.90 in a 3300 lb car.
Ed Wright 4156 SS/JA
Old 06-23-2016, 09:23 AM   #6
pfordamx
Liked 7 Times in 5 Posts
i'm curious if this is wheel or flywheel hp too, and my other curiosity is if your mph show significantly less hp than e.t. at the same weight does that just mean you have a efficient car?
pfordamx is offline   Reply With Quote
Old 06-24-2016, 11:06 AM   #7
DeuceCoupe
Liked 48 Times in 44 Posts
It looks like the Wallace link uses NET flywheel power. Then they make assumptions to translate that to rear wheel power which is what move the car. Note they say the formula is just approximate, eg they don't even ask what transmission you have.
If MPH is low it can mean a bunch of stuff
1. Running out of fuel on top (common in my old junk)
2. Running out of revs
3. Brick-like aero or headwind (a 5mph headwind will reduce trap speed about 1mph - varies by car of course)
4. Other
If you have open headers, not too many belt drives, a big air filter, and cold air coming in, NET horsepower will get really close to GROSS horsepower. Still some losses to get to the rear wheels, no way around that.
Old 06-24-2016, 11:20 AM   #8
pfordamx
well a amx isn't the most aerodynamic car i can think off and the ets and mph i was using were from a day when we were driving in to a 20 mph head wind but it was good cool air.
Old 06-24-2016, 12:55 PM   #9
Jim Caughlin
Liked 805 Times in 245 Posts
4. Other
In a somewhat strange mathematical coincidence, optimal ET x MPH in 1/4 mile tends to equal 1320 (example 10.00 ET x 132 MPH = 1320, 11.00 ET x 120 MPH = 1320) so you can use that number as a baseline. As we know, MPH tells you how much HP you are making, the 1320 number gives you a reasonable idea of how well you are getting it to the ground. Not surprisingly, high HP cars tend to be a little over the 1320 number, low HP cars under but usually not by much.
Jim Caughlin
SS 6019
Jim Caughlin is offline   Reply With Quote
Old 06-24-2016, 01:22 PM   #10
Hans Olsson
Hans Olsson's Avatar
Jim Caughlin
SS 6019
Very good explanation.
Hans Olsson is offline   Reply With Quote
