#31 | ||
Liked 759 Times in 379 Posts
FYI, all your ET is made in the first 330 feet and 60 foot is EVERYTHING! Last edited by 1320racer; 07-01-2016 at 05:02 PM. |
#32 |
Liked 7 Times in 5 Posts
Have to agree that conventional wisdom would say a 280@ .050 cam is going to want at least 11 or 12.1.
#33 |
wrong, MORE!
#34 |
ok enlighten me so the compression isn't whats wrong with the cam i know theres alot too picking a cam displacement, compression, cylinder head flow, velocity exhuast port vs intake flow low lift vs high lift and whole list more but a general statement a that a bigger cam will work better with more compression i don't see as being completely wrong.
#35 | |
#36 |
Liked 1,937 Times in 582 Posts
In my opinion ATI is the best. I have had an ATI converter in my car for all of my career with an auto. There are several others that are good as well.
Mike Pearson 2485 SS |
#37 |
Liked 880 Times in 311 Posts
I have been dealing with customers for over 45 years that have the same problem you do. I call it testosterone poisoning. Some how the camshaft and cylinder heads are where this disease is usually found. The bigger is better disease. What you have is very little dynamic compression with the low static and the high cam duration @ 50. An engine does not operate on just static compression. the closing point of the intake valve vs the static and other engine parameters makes the dynamic. For instance I have a SS Modified engine that has 15.8 static and a 282 @ 50 cam shaft. Where I have the cam installed it pumps 225 lbs on the 4 th hit. It makes 2.5 hp per cu in. What we are all trying to tell you is the engine may be making hp at high RPM it is not making TQ with that long @ 50 cam and the low (relatively) static compression. That is why it likes the slipping converter. It take cylinder pressure to make power. In dyno terms it is BMEP and it usually happens around peak TQ. The trick to making real power is to extend/expand the RPM band of peak BMEP. To do that you need air and fuel to make the cylinder hotter. It is all about Heat and pressure. You need more pressure...Talk to your favorite cam guy, and no offense, not the minimum wage Cam Help salesman. The guy that knows what a cam does. don't start the conversation out by telling him the size cam you want. You already have the results of that. OK, you have my .02 I'm finished. It is late and my pillow needs some head...
Adger Smith (Former SS) Last edited by Adger Smith; 07-02-2016 at 12:19 AM. Reason: sp |
#38 | ||
As I stated previously, his current cam is about 40 degrees too big at .050 and we have no clue to how much lift or the LSA. Installing the right cam with ~40 degrees less duration at .050 will make ~ 100 more ft./lbs torque at peak and ~ 60 more HP at peak and peak RPM will be lowered by ~300. This engine will require a shift point of ~ 6200, a converter that flashes to ~ 5000 RPM and be geared to trap ~ 6800 RPM. More importantly it will accelerate his 2600 lb. bucket of bolts quicker and faster than it's current performance! Last edited by 1320racer; 07-02-2016 at 07:45 AM. |
#39 | |
I'm listening. Thanks for the input. I will definitely look into experimenting with different cams. It sounds like it would pay to find a shop that has a dyno that will accommodate something besides a SBC. I've had a few members contact me with some helpful information and I appreciate that. |
#40 | |
I understand cylinder pressure and what components affect it but, I can't figure volumetric efficiency or dynamic compression. I understand what you are trying to tell me but, I do know this..........a N/A 340 will not run better, if it's geared to cross the finish line at 6800 RPM. That would be like switching to a 4.30 gear with my current 31.2" tire just to match 135 MPH. No Way. We have turned the post from shift points to torque converters to camshafts........and I'm completely OK with that. I'm learning! I'm even looking into a different car to try to build a super stocker. Just guessing, I'm going to say peak HP is about 7000 RPM and Peak TQ probably 5400 RPM. |
