Old 07-17-2016, 03:56 PM   #11
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Default Re: Power valve?
I always blocked the PV on my carbed stocker. You have a different load now compared to when it had a converter.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 07-17-2016, 04:22 PM   #12
BLIND MULE
BLIND MULE's Avatar
I have had quite a few alky carbs seen and rebuilt others for friends and have NEVER seen one with a Primary or otherwise PV! Not sure it's real common?
BLIND MULE is offline   Reply With Quote
Old 07-17-2016, 06:56 PM   #13
Dana Fitzpatrick
Liked 10 Times in 6 Posts
Sean
Thanks,Sean. I wondered if that's the problem,the converter flashed to around 5,800. Thanks.
Dana Fitzpatrick is offline   Reply With Quote
Old 07-17-2016, 09:26 PM   #14
Woodfin
Liked 288 Times in 109 Posts
BLP and APD both use primary power valves with Methanol. I should have said, "power valve usage with Methanol in common with BLP and APD"
Yet, I am off subject for the original question, I apologize.
Old 07-18-2016, 06:38 AM   #15
Makinchips
Your running on the transition circuit in the pits, it's prob lean. Power valve has nothing to do with that unless it leaks. Then it will pull fuel down the vacuum port behind it.
Makinchips is offline   Reply With Quote
Old 07-19-2016, 01:13 PM   #16
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
My APD HP1000 methanol carb has never had a power valve in it. I've had 3 methanol carbs over the years, and none have used power valves.
S/ST 51
S/C 53
Old 07-23-2016, 07:22 AM   #17
Philip Baise
Take it out and plug it. It does not affect idle or transition to the booster. Yes it works on engine vacuum ,but it only richens the mixture when the vac is low and the engine is pulling fuel thru the boosters. You should bump your primary jet size up if you do take it out. on our 585 we usually go 76 pri and 78 sec. 396 motors 78 pri and 80 sec.
Philip Baise is offline   Reply With Quote
Old 07-23-2016, 11:10 AM   #18
Dana Fitzpatrick
Thanks for all the replies,they give me some good direction on fixing the problem.
