Old 07-19-2016, 09:56 PM   #1
js72mav
Default Break in oil
Hi Guys,
How are you guys doing your break in procedure when dealing with break in oil? How long are you running it? Things like that. Are you going straight to synthetic oil right after?
Thanks in advance,
Jamie
js72mav is offline   Reply With Quote
Old 07-20-2016, 02:11 AM   #2
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default Re: Break in oil
Nothing special here...Castrol 5W-30 from start to end.
Rich Taylor
I/SA - 321
Old 07-20-2016, 08:25 AM   #3
Eman
Liked 133 Times in 76 Posts
Start engine, break in, drain oil, remove filter and cut open. Replace with whatever oil and filter you plan on running and go race.
The idea of an engine break in is to allow the parts to "wear" to each other. Why would you want all of those wear particles in a motor any longer than necessary? I also install neodymium magnets throughout to catch metallic particles.
Old 07-20-2016, 12:01 PM   #4
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Break in oil
I go through several (4-8) heat-cool-heat-cool cycles, not letting it get too warm initially because of the bearing & ring clearances. Running duration depends on radiator efficiency & amount of hard-block. Check everything, put race springs in if breaking in with softer springs, drain oil while still warm, refill with synthetic race oil and go!
As mentioned, magnets and cutting the filter open are always a good idea. I always use a magnetic drain plug for ongoing checks.
Amsoil has a break-in specific oil that works well.
LOCOMOTION Racing
Old 07-20-2016, 12:12 PM   #5
Ed Wright
Ed Wright's Avatar
Had really good luck with ring seal using Driven BR30. It is 5W30 wt.
Ed Wright 4156 SS/JA
Old 07-20-2016, 09:04 PM   #6
Monte Howard
Monte Howard's Avatar
Liked 71 Times in 23 Posts
Call HP lubricants in Manteno,IL, you won't be disappointed. Run it the first race or as long as you want. Their racing oil line is called Badd Azz racing oil.
Monte Howard 3209 STK, 3208 SS
Monte Howard is offline   Reply With Quote
