#11 |
Liked 237 Times in 126 Posts
Here's my take. If you floor the pedal on a two step set at 3000 or so, the butterflies go wide open and the pump shot from a double pumper is expended with the car on the line. If you rev until you just hear the stutter kick in you still have throttle travel in reserve and get the pump shot when the engine goes under load at launch. I haven't raced enough to tell the difference but I feel more like a racer when I mash the pedal on the last yellow...I mean green light...
Dale
#12 | |
Liked 33 Times in 16 Posts
Rich Taylor I/SA - 321 Last edited by HandOverFist; 08-08-2016 at 02:21 PM. |
#13 |
Liked 503 Times in 131 Posts
On a two barrel beast like the Gremlin, there is a noticeable difference. With two step the extra accelerator pump shot, can help with reaction time, and car launches tamer, a tick quicker .01 for same launch RPM 60 foot. 1/4 mile no real difference. However the car launches much harder off footbrake and mashing it, and you can adjust your RPM up and down as needed for reaction time.
My fuel injected cars/trucks seem to really like 2 step. Test with dakota a couple of years ago was .02 quicker in 60 foot and .03-.04 quicker in 1/4 mile. For real accurate data, you would want to datalog the throttle position just to make sure you are at 100 WOT especially if you have wheelstand or hard landings going on also.
Eric Merryfield 1883 STK |
#14 |
Liked 53 Times in 16 Posts
I find this a interesting subject as I have never raced a "real automatic race car" I learned to race with my 68 Impala stocker with the Jerico 4 speed which I just floored the pedal to the desired RPM set on the 2 step (usually 5500 - 6500) So in building my 65 Impala I wired 2 step through a Brake pressure switch with a on/off toggle to activate the system. I assume with a 2000-3500 rpm range I will mash pedal on 2 step.
I will also be running the Holley version 396/325 Building motor now, can't wait to race. This "bench racing" gets played. Will Lamprecht 1965 Impala I/SA almost finished. |
#15 |
Liked 101 Times in 27 Posts
[QUOTE=HandOverFist;511057]Not by intent, but rather by design Rusty. As you can see in the image the activation button is in the brake pedal itself...I know some use a micro-switch.
![]() you almost answered my question.....why aren't you putting the gas pedal on the WOT on the floor instead of stopping when you hear it break up ???? Is it any faster not to mat it ???
NHRA AND IHRA STOCK ELIMINATOR 2772 |
#16 | |
[quote=Rusty Davenport;511598]
Rich Taylor I/SA - 321 Last edited by HandOverFist; 08-15-2016 at 01:57 PM. |
#17 | |
[quote=HandOverFist;511600]
#18 | |
[quote=Rusty Davenport;511603]
I see this less often now with the current 383 engine/PG combo as the converter installed is not really optimal for this set-up.
Rich Taylor I/SA - 321 |
#19 |
Liked 4,379 Times in 502 Posts
I don't know how much about two-steps on a carb motor but an EFI motor must be tuned to do both. Footbraking launch RPM puts you in a lower load cell section on the fuel map and the transition to the high load launch must be smooth and have that accel enrichment stuff all tuned properly. The two step puts you in a high load cell as soon as you drop the pedal to the floor so all accel enrich stuff is finished before actual launch so you are transitioning between high load cells.
#20 |
Liked 239 Times in 79 Posts
Rusty-
My experience has been .008-.012 quicker in 60ft ET with a two step switch (same launch RPM) This equates to .016-.024 improvement in 1/4 ETs. It should be noted that to leave matted off of a 2-Step, the carb requires a different set up (think secondaries). My experience with fuel injection stockers mirror Eric and Bobby ( you stand to pick up a little more ET). I suspect this has to do with the amazing starting line efficiencies with FI (compared to the "quadra-bogs") Feel free to call with questions buddy! PS- I surround myself with much smarter people than myself! 😁 |
