Old 08-19-2016, 11:15 PM   #1
Dale Rethke
Default Look Out!!
Friday BIR incident.
http://www.dragzine.com/news/video-t...e-in-brainerd/
Dale Rethke is offline   Reply With Quote
Old 08-20-2016, 10:29 AM   #2
FED 387
Liked 334 Times in 181 Posts
Default Re: Look Out!!
Wow-- broken axle perhaps??? Lucky no one was run over. There's always several starting line crew standing in that area. FED 387
Old 08-20-2016, 11:07 AM   #3
Bob Gullett
Bob Gullett's Avatar
Liked 510 Times in 117 Posts
Was watching it on Allaccess and saw that happen. All things considering it could have been worse. Glad the driver was ok. When I saw this happen though it hit home. 2 weeks ago we were planning to go to the Seattle divisional race. Was looking at my log books and realized I had 120 runs on the gear set. Decided to check them and noticed a couple of cracks. So was going to put in a new set. When I pulled out my left axle to my surprise (and shock) I found a twisted axle spline. I hate to think what might of happened if I hadn't checked it. Needless to say I have new axles ordered. And I'm updating to a 35 from 33 spline.
68 Chevy11 327 F/S
Bob Gullett is offline   Reply With Quote
Old 08-20-2016, 11:31 AM   #4
FED 387
smart move on your part---take a look at your axles every so often they will get an ever so slight "twist" in them especially the smaller diameter axles 28-31-33- some times a 35 too-- depends on the weight and power level range you are operating in your's definitely looks like it wants to break SOON---
Old 08-20-2016, 12:39 PM   #5
Fireofficer5
Liked 33 Times in 20 Posts
Just for my own information, why ddin't the axle splines slide all the way in?
Fireofficer5 is offline   Reply With Quote
Old 08-20-2016, 01:16 PM   #6
Bob Gullett
That's the way I got them from Strange years ago. I have Mark Williams axles on order.
68 Chevy11 327 F/S
Old 08-23-2016, 07:15 AM   #7
Fireofficer5
Thank you.
Old 08-23-2016, 07:57 AM   #8
Bobby DiDomenico
Liked 101 Times in 52 Posts
Looking at the wear pattern I'd say they did go all the way into the gears. The splined area just happens to be a little longer.
Old 08-23-2016, 09:51 AM   #9
Ok stocker
Liked 100 Times in 24 Posts
It is possible the axles are designed for multiple applications and some may be deeper.
Ok stocker is offline   Reply With Quote
