Old 08-15-2016, 08:48 PM   #11
Dave Casey
Liked 774 Times in 164 Posts
Default Re: Trailer ramps
many trailer floors are made from aluminum and the pieces are 12" wide. I think they are extruded and often you can buy them . My Gold Rush trailer is this way. My guess is they are 2" deep , the sides flange back in and in the center is a T. kinda like the letter E sideways
Dave Casey 1330 STK
Old 08-23-2016, 08:58 PM   #12
G Anderson
Liked 4 Times in 3 Posts
Originally Posted by Jim Caughlin View Post
6061T6 can be bent but the inside radius of the bend has to be 4 times the material thickness so assuming 3/16 thickness, the inside radius needs to be 3/4". Assuming that you are building alum ramps to minimize weight, the 6061 option is going to be the best weight to strength ratio. 3003 does bend easily but has the strength of a wet noodle. 5052H32 might be a better compromise but I would opt for the 6061 alloy.
Jim Caughlin
SS 6019
Jim-JR : At 66" long that would be bending with the grain might possibly open up? On 6061 best to bend against the grain.
G Anderson is offline   Reply With Quote
Old 08-27-2016, 06:58 AM   #13
Wayne W
Wayne W's Avatar
Liked 3 Times in 1 Post
Or just find a set from an Auto-transport like this guy did. It may be easier and stronger than building your own. Just a thought .
Wayne W is offline   Reply With Quote
Old 08-27-2016, 08:12 AM   #14
J.R. Haddad
Liked 1,464 Times in 307 Posts
Guys, thanks for all the help. The fellow who was building the ramps
for me got hurt in a motorcycle accident and wasn't able to
complete the ramps, so I purchased a set from PitPal. I installed
them, they work good, look good, and lessened the aggravation factor.
Thanks again, J.R.
J.R. Haddad is offline   Reply With Quote
