Old 10-18-2016, 05:09 PM   #1
MEXJOE
MEXJOE's Avatar
Liked 165 Times in 51 Posts
Default Wtb 35 spline 12 bolt spool
Looking to buy a 12 bolt 35 spline Strange spool.
218.426.4OO9
Glen
Thanks
Glen DeMenge
1969 Camaro Stock Eliminator
MEXJOE is offline   Reply With Quote
Old 10-26-2016, 09:00 PM   #2
Dennda709
Default Re: Wtb 35 spline 12 bolt spool
I have a Mark Williams version. Let me know if your are interested. Thanks.
Dennda709 is offline   Reply With Quote
Old 10-27-2016, 08:06 AM   #3
Thomas Arnett
I have a 35 spline alum MW spool with 3.25 large bearings never used.500.00.
Thomas Arnett is offline   Reply With Quote
Old 10-27-2016, 12:57 PM   #4
Dyno
Dyno's Avatar
Liked 695 Times in 206 Posts
The Strange 35 spline is different than the Mark Williams 35 spline.
Old 10-27-2016, 01:52 PM   #5
Bill Hatcher
I have two Strange 35 spline if you are interested. Bill Hatcher 620-629-7333
Bill Hatcher is offline   Reply With Quote
Old 10-29-2016, 10:06 AM   #6
Eddie Rezac
Liked 63 Times in 7 Posts
Smile Re: Wtb 35 spline 12 bolt spool
I have a nearly new 35 spline strange aluminum, big bearing spool. After many hours of research I have found an aircraft landing gear bearing, that can be used directly into a 12 bolt housing without any machining at all. This bearing can also be used with MW big bearing spools, fitting into stock, 12 bolt housing, or a strange, small bearing aluminum, 12 bolt case that is used in a ford 9" housing. eddierezac@yahoo.com
Eddie Rezac is offline   Reply With Quote
