Old 10-29-2016, 10:28 AM   #1
brian schuetta
Liked 28 Times in 15 Posts
Default BBC Valves 11/32 Stem
Anybody have a source for BBC valves 2.25 & 1.88 with 11/32"stems? I found some Ferrea types for $40 each but looking for something cheaper. To be used in a bracket motor.
brian schuetta is offline   Reply With Quote
Old 10-29-2016, 10:52 AM   #2
MAURICE BLENDHEIM
Liked 285 Times in 87 Posts
Default Re: BBC Valves 11/32 Stem
Try Competition Products. MB
MAURICE BLENDHEIM is offline   Reply With Quote
Old 10-29-2016, 01:54 PM   #3
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Manley Severe Duty valves are available everywhere for under $30 each .
Cheap valves are just cheap to buy , when the head comes off one of the intakes and takes out your piston ,head and maybe the whole engine ,they aren't cheap anymore.
And yes ,I have personally been taught this lesson , more than once .
Don't take this as a knock, but most Bracket racers tend to believe lower spring pressures make the engine live longer , but nothing could be further from the truth .
Higher spring pressures help keep the valve from bouncing when closing , this especially true with a BBC intake valve.
Valve bounce causes most failures .
Old 10-29-2016, 09:07 PM   #4
brian schuetta
I understand that. I m trying to take weight out of the valve train and the heads have 11/32 guides already. I wanted a valve that is narrowed behind the head also. Are tool steel retainers a good move?
Old 10-29-2016, 09:11 PM   #5
Tim H
Tim H's Avatar
Liked 482 Times in 159 Posts
Yes, as to the tool steel retainers. Also just to add many Edelbrock BBC heads are equipped with 11/32 stem valves ... just sayin ... And I think I have a set of Dart Pro 1 heads that came with 11/32 as I recall
Old 10-30-2016, 05:55 AM   #6
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Brian, FYI...
I ran Manley Severe Duty 11/32" stem valves, 2.25/1.88 in my cast iron oval port heads atop my roller cammed 700+HP 468 BBC bracket engine for many years and thousands of passes turning 7400rpm in the lights. Those valves were actuated with Manley polished Nextek springs # 221443P 235 closed/610 open. Never broke a valve, valve spring, rocker arm, rocker stud, etc.
Further, the valves in my Brodix 3 xtra heads atop my 522 are 11/\32" stem as are the valves in my Brodix HH heads atop my 600" engine.
