Old 11-17-2016, 01:31 AM   #1
James L Miller
Liked 25 Times in 16 Posts
Default Mopar 273-4bbl Combo
I bought a 1966 Dodge Dart off a local Stock/SS racer in the DFW area. It's pretty much just a roller at this point, but it has a cage already in it. My plan is to run it in Stock, natural K/SA at 13.47 #/HP, probably drop down to L/SA. So far, just have a couple of blocks, cranks, picked up some 920 heads at a local swap meet, bought an LD4B and a 1967 273 AFB off Terry Dye. I made a post over on Moparts about valve selection that works in these heads, and some body suggested I put a post over here. So, if anyone has any info they are willing to divulge (buy this, don't buy that, you're a loon for running a Mopar, etc.), please post or send me a PM. Thanks.
Mopar 2 Ya!
Old 11-17-2016, 01:31 PM   #2
Jim Hanig
Liked 99 Times in 49 Posts
Smile Re: Mopar 273-4bbl Combo
I would contact Matt at victory engines he run one in ss and sure he could point you in the right direction. hes in Marshall mn
Old 11-17-2016, 02:30 PM   #3
Hacksaw
Liked 312 Times in 175 Posts
Default Re: Mopar 273-4bbl Combo
I used to run a 340 Mopar. When I saw the ports on a 273 I couldn't believe how small they are. If I were you I do some serious research before you commit and waste money on a weak combo. In Stock Elim., don't see it working out very well.
Old 11-17-2016, 03:41 PM   #4
jmcarter
jmcarter's Avatar
Liked 3,227 Times in 981 Posts
The Bushmakers out in D6 seem to have figured it out...Angela runs K most of the time and is up on the sheet consistently.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 11-17-2016, 03:45 PM   #5
Carguy49
Liked 3,007 Times in 721 Posts
Jim you are correct. Angela's car runs very well. It is a 65 Valiant 2dr. sedan
Ron McDowell - Did Race
Old 11-17-2016, 03:51 PM   #6
David Lee
Liked 346 Times in 126 Posts
what combo did paul wong run?
Old 11-17-2016, 05:22 PM   #7
Paul Wong
Liked 419 Times in 85 Posts
delete
Paul Wong is offline   Reply With Quote
Old 11-17-2016, 05:39 PM   #8
Jeff Teuton
Liked 325 Times in 50 Posts
Was the Chrysler Marine 340-4 Super Bee engine with the 4bbl steel manifold, the same as that motor. We have one laying around somewhere.
Jeff Teuton 4022 STK
Old 11-17-2016, 05:57 PM   #9
David Lee
Originally Posted by Paul Wong View Post
I run both the 2 and 4 bbl 273. The 4 bbl I run with a 4 speed though. This combo will run fine. Its just not cheap or any kind of a dime rocket. The 273 4 bbl cost about the same to build as my 440 6 BBL.
may i ask, who did your 2 barrel carb?
Old 11-17-2016, 06:39 PM   #10
Paul Wong
delete
