Old 12-11-2016, 05:55 PM   #1
J.R. Haddad
Liked 1,467 Times in 307 Posts
Lightbulb Camshaft roller bearings
Are you allowed Roller Bearings on the cam in Stock?
Thanks.
J.R. Haddad is online now   Reply With Quote
Old 12-11-2016, 08:05 PM   #2
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Default Re: Camshaft roller bearings
Thanks.
Is it for safety??????????????
Bob Mulry 7516 STK
A & M Motorsports
Old 12-11-2016, 08:23 PM   #3
Ed Wright
Ed Wright's Avatar
Do they allow 52 or 55mm cam cores?
I always ask my Div Tech Director questions like this. Does the rule book mention them? They tell me, if it doesn't say you can, you can't.
Ed Wright 4156 SS/JA
Old 12-11-2016, 09:28 PM   #4
Bill Diehl
Bill Diehl's Avatar
Liked 9 Times in 8 Posts
Not to open up the ant farm but I would chalk this up to the lifter rule that's just been clarified even though "some" been running them for years...same for the .842/.875/.904 dia. everybody knows whats supposed to fit where....but
carry on with the discussion
Bill Diehl B200 C/D STK
Bill Diehl is offline   Reply With Quote
Old 12-11-2016, 09:47 PM   #5
J.R. Haddad
Talking Re: Camshaft roller bearings
Bob, I think it would enhance safety. Less chance of locking up the motor!
Old 12-12-2016, 06:33 AM   #6
Alan Nyhus
Liked 799 Times in 236 Posts
J.R.: Roller bearings only if the engine was originally equipped with them. Rollers in rollers, babbitts in babbitts. Cam journal size can be changed.
Stay warm. -Al
"That'll never work....."
Old 12-12-2016, 09:24 AM   #7
carl hinkson
Liked 18 Times in 10 Posts
I do a lot of cam tunnel blue printing and roller cam bearings seem to be a thing of the past. Roller cam bearing transfer alot of harmonics though the valve train.
I see alot of BBC cam journals (2.120 housing bore ) for the OEM GM blocks using the GMP-1
I have custom 55MM babbit cam bearings for a 2.282 housing bore which seems to be very common in SBC, BBC, and the SBF
What block was the OP talking about.
carl hinkson is offline   Reply With Quote
Old 12-12-2016, 09:29 AM   #8
carl hinkson
Thanks.
What block are you talking about ?
Old 12-12-2016, 08:11 PM   #9
J.R. Haddad
SBC 010 Block or Dart replacement. Thanks. J.R.
Old 12-12-2016, 08:40 PM   #10
carl hinkson
A 010 block you can't go with a 55MM cam it will push the oil band of the lifters up out of the lifter bores because of short lifters bores. Plus going to a 55MM with Babbit cam bearings you have to machine the cam tunnel to 2.282 and when doing the annular oil grooves in back of the cam baring there is a good chance of getting into the water jackets.
The Dart SHP Pro block comes with BBC cam tunnel and .904 lifter bores, I have gone to 55MM babbit cam bearings in those blocks with no problems.
What lifters can you run ? Roller, Flat tappet ?
