Old 01-09-2017, 07:37 AM   #1
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Default Mikronite vs REM
Need to know more about these two processes for Gears.
Also are there other products and processes to consider.
Been reading about both...
But found one more Cryogenics...
Are these worth it especially for reliability?
Dan
Old 01-09-2017, 09:14 AM   #2
Jim Bailey
Liked 584 Times in 94 Posts
Cool Re: Mikronite vs REM
Dan, both processes will work fine and improve gear life as well as performance. Combined with Cryo, you will really see an increase in gear life, especially when "Pro Gears" are not available for you application. Before I Cryo'd and Rem finished the gears that I use to run in my 8 3/4 Dodge max wedge combo, I was getting about 40-45 runs before knocking a tooth off. And I tired several different gear manufactures...After Cryo and Rem, I was taking them out at 120, only because I was getting scared of them. Treated Gear Sets do require a slightly different set -up. Also, make sure you deal with a company that has experience and quality equipment.
Jim Bailey is offline   Reply With Quote
Old 01-09-2017, 09:38 AM   #3
Randall Klein
Liked 316 Times in 67 Posts
Default Re: Mikronite vs REM
Curious if either process works on used gears or new only?
Old 01-09-2017, 11:21 AM   #4
Dan Fahey
Dan Fahey's Avatar
Thanks Jim:
Not making as much power as your car.
My Pure Stocker uses Moser Street Gear.
They have many miles and runs on them.
Looking at more gear as the car is trailered.
So seeking some reliability.
Plus they claim some performance improvement.
D
Old 01-09-2017, 11:24 AM   #5
Dan Fahey
Dan Fahey's Avatar
What gear fluid do you use after you Cryo/REMed you gears?
D
Old 01-09-2017, 11:28 AM   #6
Hacksaw
Liked 312 Times in 175 Posts
Curious: What's slightly different on the set -up involving treated gears?
Old 01-09-2017, 12:50 PM   #7
John Dinkel
Liked 263 Times in 68 Posts
Thumbs up Re: Mikronite vs REM
I used Synthetic 75-90 Mobil 1 on mine. The gears were Chryo and REM finished.
John Dinkel 3295 STK
John Dinkel is offline   Reply With Quote
Old 01-09-2017, 02:13 PM   #8
Dan Fahey
Dan Fahey's Avatar
Since the surface is flatter and finer you can set the Ring and Pinion with a tighter clearance.
There is less friction, less heat and part expansion.
Slipperier tighter touch should provide a better feel and response time.
Dan
Old 01-09-2017, 02:39 PM   #9
Jim Bailey
Dan, the best results we had were with the Pinion Depth slightly deeper than recommended, into the ring gear, then making sure the backlash was set a the tightest spot you can find rotating the ring gear. "IF" then the backlash seemed too lose the rest of the rotation, we didn't worry about it. The only time we got into trouble was with the set up being too tight. My guess is the Cryo'd and Rem'd gear sets don't "wear in". For lube we always ran 75/90 synth. keeping in mind that we always ran max capacity. None of that 1/2 to 1 quart B.S. Your ring and Pinion is a very high load area in your race car that requires lube at all times. Not saying this is right, but it worked for me ... hope it helps.
Old 01-09-2017, 04:00 PM   #10
Bench Racer
Liked 99 Times in 21 Posts
I have no experience with setting up gears but was carrying on a conversation with a guy that set up diffs and trans for Nascar and circle track guys. He said one of the benefits of "treated" gears vs. a non treated ring and pinion the set up was the treated gears pretty well stays constant. He said on a non treated diff you need to keep a frequent checks to insure the clearances stayed where they should be.
Bench Racer is offline   Reply With Quote
