Old 02-01-2017, 04:17 PM   #1
Mike Fuller
Liked 203 Times in 80 Posts
Default 12 Bolt 40 spline spool
I can not find anybody who makes these spools. I have one in my possession now and am considering making them if I can draw enough interest. Chime in if you have input about this topic.
Mike Fuller 396 STK
3961 SS
Old 02-01-2017, 04:35 PM   #2
Mark Markow
Mark Markow's Avatar
Liked 9 Times in 3 Posts
Default Re: 12 Bolt 40 spline spool
I don't think it would sell that well, in order to use the 40 spline spool, you need at least 3.250 bore housing. those are only available in a new aftermarket housings. the stock housings are 3.062 bore, . secondly the 40 spline I.d. on a 3.250 o.d. on the bearing is marginal for strength , thirdly if a 35 spline axle isn't enough for your application, you should be looking at a dana 60 or 9'' in my opinion.
Mark Markow
171 ss/tb
Mark Markow is offline   Reply With Quote
Old 02-01-2017, 04:54 PM   #3
Dragsinger
Liked 99 Times in 60 Posts
Agree with Mark about a limited application. At the performance level of needing a 40 spline axle, the 12 bolt gear set is beyond the design limits.
Larry Woodfin 471W
Old 02-01-2017, 07:32 PM   #4
rx dealer
Liked 53 Times in 13 Posts
Mike, Strange makes one, It's for the 12 bolt drop out center section that fit a 9" housing.it's used by the comp guys. I have one in my Race car. I run a DTS 12 bolt housing with MPR chromoly tubes...Luke
rx dealer is offline   Reply With Quote
Old 02-01-2017, 07:57 PM   #5
Mike Fuller
Strange no longer makes it. Like I said I have one now and the application that you talked about is what I plan to use it for.
Mike Fuller 396 STK
3961 SS
Old 02-01-2017, 10:14 PM   #6
Eddie Rezac
Liked 63 Times in 7 Posts
Smile Re: 12 Bolt 40 spline spool
There are bearings, that will fit a stock, 12 bolt housing bore. These bearings fit this 40 spline spool, plus the Strange & Mark Williams aluminum 35 spline spools. These are very expensive, aircraft landing gear bearings, but you do not have bore the housing, to use these spools. Google my name to find my contact information.
Eddie Rezac
Eddie Rezac is offline   Reply With Quote
Old 02-02-2017, 08:32 AM   #7
rboyle
rboyle's Avatar
Liked 586 Times in 162 Posts
I have one for sale, $100 used but very good condition. 12 Bolt Chevy Ford drop out takes Strange axles.
Call me or PM if interested.
(631)461-6761
Old 02-02-2017, 04:20 PM   #8
rx dealer
Mike, I think it would sell in a complete package. the A-D stockers or super stockers.
Spool
Axles
Housing
Bearings
and maybe choice of brakes. Complete or pieces ...just thinking...Good Luck
Luke
Old 02-10-2017, 02:44 PM   #9
Mike Fuller
Eddie, will the mark Williams work in the Strange 12 bolt drop out case?
http://www.markwilliams.com/detail.aspx?ID=549
Mike Fuller 396 STK
3961 SS
Old 02-10-2017, 05:25 PM   #10
Eddie Rezac
Mike,
It will work. There are 2 different Strange 12 bolt drop out carriers that fit the ford 9 inch housings. One uses the larger ford type bearing, the other uses the small 12 bolt type. I have the aircraft bearings that fit your 40 spline spool, into the small bearing strange drop out, or a stock 12 bolt housing. We are running both types with Mark Williams spools & axles in my son's, Ecotec powered, Opel GT.
Eddie Rezac 402 443 8424
