Old 02-11-2017, 07:16 PM   #1
Max Wedge
Default Engines for sale something for everyone
Have way to much too list. Email or pm for descriptions.
1). 400 Chevy 2 bolt main block mag good standard bore
2) 12 Valve 5.9 Cummins machine work done
3) 454/468 bracket engine 9.30's in Nova 512 4 bolt filled
4) Wisconsin VH4D. All new parts and machine work done
5) 355 4 bolt street HP long block 275HP? Cheap
6) 355 4 bolt hi test HP long block 400 HP? All forged internals, Vortech top, balanced, hydraulic retro roller, nice engine
7) 413/426 A/SA max wedge short blocks (2) and related components (Manley, CP, Comp, Bullet, both blocks 4.310 bore, have room in blocks. One cheap, other more expensive. Best et 10.46 @ 127 in 3300DA without trick top end.
8) 727 pushbutton transmission with Cheetah valve manual body, reverse pattern, updated input and output tail shaft, bracket race or spare stocker
9) 30 x 9 MT radials, 1/2 gone
10) 29.5 x 10.5 MT bias slicks, plenty left
Everything needs to go and priced fair,
Located in Northeast Ohio
Jeff Day
Max Wedge is offline   Reply With Quote
Old 02-12-2017, 07:24 PM   #2
mannymen
Liked 13 Times in 7 Posts
Default Re: Engines for sale something for everyone
Post selling prices for items 3, 5 and 6.
Thanks
N/A
mannymen is offline   Reply With Quote
Old 02-14-2017, 04:05 AM   #3
Max Wedge
Please PM or post with what parts you are interested and I will give you prices. Most items have a lot that goes with description, I didn't want to have a 5 page add describing everything.
Thank you for your interest.
Also, thanks Classracer.com for the free ad!
Old 02-18-2017, 07:51 PM   #4
Max Wedge
Sorry for the delay!
#3. 1970 dated 454 512 casting 4 bolt main block, freshly/professional machined in January 2017, decided to go with new 540. Block is 3/4 filled, ARP main studs, align honed, coated cam bearings and fresh clean up hone on a +.060 bore. Block needs final washed and ready to build. $1,200.
Eagle 4340 H-beam rods 6.135 length with +060 over CP big open chamber domed pistons on them, both came out of engine in October, 2016. $800 for rods and piston combo. No crankshaft with engine, it was cracked upon mag test.
Roller camshaft $150
Dart 310 Pro 1 rectangular port heads. Had new Manley Nextech springs and titanium retainers installed 12 passes prior to end of 2016 season. Very nice pair of heads, nice condition, not beat up junk, over $3,000 new pair, sell for $1,750 set.
Will give another 10% off each component you buy all above.
Also have intake, oil pan, lifters etc available.
#5. 355 010 casting 4 bolt assembled all fresh machine work, never fired. Block +.030, fresh cast crank, factory rods, cast flat top 4V pocket cast pistons, Summit hydraulic cam, under. 500 lift, fresh 882 heads with all new valves and valve train parts, used aluminum dual plane intake, long block assembled and painted Orange. Would cost easy $3,500 for a speed shop to duplicate, must sell $2,000. Again, will give further discount if buyer takes another engine.
#6. As stated in original post, this is a nice and expensive engine. Was professionally machined, balanced and built. 010 casting 4 bolt, freshly +.030 bore with deckplate, align hone, square deck, performance cam bearings, and ARP bolts throughout, all parts/ bolts/ tin/ etc etc brand new. Only used parts was block and 1182 GM steel crankshaft prior to start of build. Steel crank fresh. 010 under, Eagle SIR 5.7 bushed rods, Sealed Power forged flat top 2V pocket flat top pistons 10.2 to 1 compression ratio. Moly rings, Clevite 77 bearings, Felpro gaskets, Glen Styers custom ground hydraulic roller camshaft and his high end Crane style retro fit roller lifters, Cloyes hex-a-just timing set, new pan, covers and balancer. GM marine Vortech heads. Fresh multiple angle valve job, magnaflux, surface cut, guides, Springs, stainless valves, etc. New polished hi rise dual plane 4 barrel intake. Roller tip Comp rockers.
Invoices on this engine were $6,378. Will sell for $5,500. Why wait to have a shop build? This stuff isn't mail order crate motor low quality, this is professionally custom built engine. Will also take 10 % off if buying 2nd engine.
Thanks for your interest and thanks Classracer.com.
Old 02-18-2017, 11:44 PM   #5
David Lee
Liked 346 Times in 126 Posts
price? and shipping to 90277
Old 02-19-2017, 01:37 AM   #6
Max Wedge
$200 pair plus shipping. I really don't know about freight I would either have to find boxes big enough or tape them together unboxed like M/T does and send. Unfortunately, this might be expensive. My zip is 44707 if you have a way of setting up shipping.
Old 02-21-2017, 02:19 PM   #7
Jess Suter
Liked 7 Times in 4 Posts
#8 any idea of ship to az 85298?
thanks
Jess
Jess Suter
7305 Stock/SS Duster
"life is not a rehearsal"
Jess Suter is offline   Reply With Quote
