Liked 169 Times in 53 Posts
I was looking on tech site and noticed someone did not pass tech because he had the stock battery held down by the factory clamp. I've always used the factory clamp on both of our stockers and never had any issues in tech.Since we no longer have a rule book to look it up I'm wondering if something has changed that I know nothing about. I've tried to use the computer to access the rule book but it's way to complicated for me.Is this one of those tech issues where it depend on who looks at your car. Thanks for any replies.
Bill Bogues 4696 STK |
Liked 125 Times in 33 Posts
Hello Bill. Here is an excerpt from the 2017 rule book, Paragraph 8.1 in the General Regulations section. It looks like 2 - 3/8 bolts required OR complete OEM hold down with original hardware but no "J" hooks permitted.:
8:1 BATTERIES All batteries must be securely mounted; must be of sufficient capacity to start vehicle at any time. Batteries may not be relocated into the driver or passenger compartments. Rear firewall of .024-inch steel or .032-inch aluminum (including package tray) required when battery is relocated in trunk. In lieu of rear firewall, battery may be located in a sealed .024-inch steel, .032-inch aluminum, or NHRA-accepted poly box. If sealed box is used in lieu of rear firewall, box may not be used to secure battery and must be vented outside of body. Relocated battery(s) must be fastened to frame or frame structure with a minimum of two 3/8-inch-diameter bolts. OEM located batteries without complete OEM hold-down hardware must be secured to OEM battery box/tray using the same 3/8-inch-diameter bolt hold-down method described in previous sentence. (āJā hooks prohibited or must have open end welded shut.) Metal battery hold-down straps mandatory. Strapping tape prohibited. |
Liked 101 Times in 52 Posts
Not sure I understand this clearly.
If I purchase a new factory 700 HP/ 11 second car I can run it bone stock sans roll cage at my local NHRA track yet if I show up with a 15 second stocker at a NHRA event I need a different battery hold down then the factory one??? |
Liked 7,742 Times in 1,740 Posts
must be fastened to frame or frame structure with a minimum of two 3/8-inch-diameter bolts. OEM located batteries without complete OEM hold-down hardware must be secured to OEM battery box/tray using the same 3/8-inch-diameter bolt hold-down method described in previous sentence. OEM hold-down can be used on battery in original location but (IMHO) common sense should probably dictate something more than the stock clamp in a high HP, wheelstanding Stocker. Relocated batteries need at least 3/8 rods.
