Old 02-19-2017, 09:52 AM   #11
GTOMayhem
Liked 22 Times in 14 Posts
Default Re: M/sa
As an entry level class, I'd say no. Not when you can run N, with no roll bar, no two year belts, no fire jacket, no spec pants.
This obviously explains the the appeal of N vs M, but I also see many cars classed into the heavier class. Is this just because of the ability to add weight where needed? I know many reclass to avoid a heads-up. What other subtlety of classing a car am I missing? I would assume most cars could get to the minimum in their natural class fairly easily, so I guess there must be more reasons to run outside of natural class, either heavier or lighter.
Rick Thomason
GTOMayhem
GTOMayhem is offline   Reply With Quote
Old 02-19-2017, 09:53 AM   #12
Billy Nees
Default Re: M/sa
There are several 78 & 79 Aspen 318 4bbl combos that will run N. Any that have a natural power to weight factor of 14 or greater will fit in the next lower class.
and the small valve motors can make it down to P. For the 20 HP difference, I'd be looking there but I'm not a Chrysler guy.
Billy Nees 1188 STK, SS
Old 02-19-2017, 09:56 AM   #13
Billy Nees
Default Re: M/sa
Rick Thomason
GTOMayhem
Some combos don't mind carrying the weight and others don't like it at all.
Old 02-19-2017, 12:17 PM   #14
Default Re: M/sa
Rick Thomason
GTOMayhem
Rick, If one is just getting his feet wet, or doesn't to put his car on kill, or just doesn't want to invest in a top shelf piece, it's advisable to be able to tech into any one of all 3 classes that you can run in.
Yes, that would include having the safety items required for M, if one can go there.
Old 02-19-2017, 03:13 PM   #15
ALMACK
ALMACK's Avatar
Liked 372 Times in 130 Posts
Default Re: M/sa
One advantage to running the lighter class is less weight to haul around from track to track.
Some indexes will favor a .05 second advantage over an index right next to it as well.
However, there is no advantage between L, M, and N.
They are all .15 sec. apart.
There is between J and K
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 02-20-2017, 08:21 PM   #16
GTX JOHN
Liked 2,493 Times in 700 Posts
Default Re: M/sa
Aspen Wagon 318 Small Valve N/0/P
My boy's 1st Car
Set National Record PLUS went to AllStars
Does have Roll Bar and Harness for Safety Sake
Still goes to Min. Wt. with my large Bottom in N!
John Irving
741 Stock
741 Super Stock
