Liked 242 Times in 81 Posts
Since I have never raced a car with a Holley on it or owned one, I have question.
I am working on a 440 6bbl car for the street everything I read says take idle vacuum and divide it by 2 to figure out the correct power valve. Is there any benefit running a high flow PV? How about on a race engine. I have my old stocker engine on a run stand and am playing with the 340 6pack setup just to learn a bit about it. Any suggestions? Thanks
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects. |
Liked 10,747 Times in 2,235 Posts
Sorry can't help, I have zero knowledge on drive ability. Only care about WOT and air-fuel.
So Larry in your race setup do you use a Power Valve? Regular or high flow?
The more I mess with the Holleys the better I like my Thermoquad.
#4 | |
Liked 502 Times in 130 Posts
Eric Merryfield 1883 STK |
#5 | |
He is the guy that knows the in's&out's of the 6-bbl. |
Liked 286 Times in 108 Posts
A reasonable suggestion is to equip them as Chrysler did originally. Also, in high-performance street trim, a 6.5 valve is common with a single carb. I estimate a 6.5 or 5.5 will be just fine.
I expect you already know, no matter what level of tune or refinement you attain, it will get "yardage" not mileage ![]() |
OK I have decided I need to step out of the dark ages and get an wide band AFR gauge.
I am thinking An Innovate LM-2 Looking on their web site and e-bay there are many options, What recommendations would you guys have? I would use it on my street cars as well as the race car.
Rod,
Before you choose the Innovate LM-2, take a look at the Daytona Sensors WEGO and the NGK. My experience is that their reading are more reliable than the Innovative and AEM. http://www.daytona-sensors.com/wego-...---8-cyl..html https://www.ngksparkplugs.com/produc...-ratio-monitor |
Liked 21 Times in 13 Posts
On paper, the LM-2 looks good. I bought one and have had problems from day 1. Tech support ranged from decent to pretty sad. If I buy another, I'd give daytona a shot.
Brian Carpenter Stock 1358 |
It seems that guys either love the LM2 or hate it. I posted this same question on another website and they can't say enough good things about Innovate. Makes it difficult to decide. The Daytona is a bunch more money and I had never heard of them until now. Maybe I should just buy a Racepack and make it portable.
Keep the suggestions coming guys.
