Old 04-03-2017, 07:28 AM   #11
nhramnl
Liked 358 Times in 83 Posts
Default Re: Holley question
I was told decades ago to remove the power valves on Holley carbs being used for all-out drag racing and simply jet the carb up 3 or 4 jet sizes. The rationale I was given (and it seems to make sense) is that power valves are devices that provide part throttle enrichment (i.e. they open when you depress the accelerator and vacuum drops to their approximate opening point), and drag race engines spend the entire run at WOT.
Old 04-03-2017, 09:21 AM   #12
Eman
Liked 133 Times in 76 Posts
The picking a power valve method of idling in drive makes no sense. The PV has no part in idling, so why idle in drive to pick a PV? If your PV is opening or effected by idle vacum something is wrong. Wrong PV could close at WOT if vacum rises. Not worth having a PV in a race engine.
Old 04-03-2017, 11:22 AM   #13
SSDiv6
Liked 1,586 Times in 583 Posts
Originally Posted by Rod Greene View Post
It seems that guys either love the LM2 or hate it. I posted this same question on another website and they can't say enough good things about Innovate. Makes it difficult to decide. The Daytona is a bunch more money and I had never heard of them until now. Maybe I should just buy a Racepack and make it portable.
Keep the suggestions coming guys.
Rod, I suggested the Daytona Sensors because you stated you wanted a good unit to use in the future in other projects.
Therefore, if cost is the issue, I would recommend the NGK unit. It works great and very affordable.
I can assure you there are many that have been disappointed with the LM-2 units due to issues and not being reliable.
Old 04-03-2017, 01:01 PM   #14
GallopinGhost
GallopinGhost's Avatar
Liked 21 Times in 13 Posts
My problem with the LM-2 was with rpm. It would not display, record, or playback anything over 2K rpm. I tried multiple work arounds as per their tech support. After a year of playing around with it, I accepted the fact it didn't work as advertised. AFR displays ok.
Brian Carpenter
Stock 1358
GallopinGhost is offline   Reply With Quote
Old 04-03-2017, 01:06 PM   #15
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Holley question
The amount of jet change needed when blocking off the power valve is determined by the PVCR (power valve channel restriction) - the 2 little holes under the power valve in the metering body. That can be as high as 10. But I never used the formula.
As for using the vacuum reading "at idle, in gear", it's just a reference to make sure that the power valve you start with isn't opening at idle, in gear. If the reading is 7" of vacuum, you'll need a power valve below that to avoid a constant over-rich condition - i.e.: 6.5, 5.5, etc.). It's simply an on/off switch. But as mentioned, it's often eliminated in a race application with success. It's more important in a street application that spends more time idling.
LOCOMOTION Racing
