Liked 99 Times in 49 Posts
Anyone out their want venture a guess on how much power one would make? Stock nhra engine.
#2 | |
Liked 373 Times in 129 Posts
10.90, 121 MPH @ 4003 pounds=553 crankshaft HP, so your looking @ 560-580 corrected STP crankshaft HP should be close. Another example: 402 350 HP, we know these make around 510 corrected STP HP with conservative heads, 510 divided by 412 = 1.23, 1.23 X 470 = 581 HP, not so sure this is a great example, but something else to consider. Another example: 260 CFM @ 28 inches X 2.2 = 572 realistic HP potential. Last edited by HP HUNTER; 04-08-2017 at 09:49 PM. |
#3 | |
Liked 309 Times in 88 Posts
Jim, I had a 454 -365 by Parsons and Meyers about 12 years ago that made 480 on their dyno. The person I bought it from said when he bought the engine that for an additional $3500 the power would have been in the 515 range.
Liked 16 Times in 11 Posts
If you still have to use the stock intake, thats a big bump to get to work.
Bob Pagano A/SA |
Liked 53 Times in 38 Posts
A certain hp to move a certain weight at 121 mph, pretty easy to figure out, law of physics 101. IMO
Mike |
Liked 279 Times in 68 Posts
480 on their Dino is probably 530 on someone else's.
Greg Hill 4171 STK |
Ya Greg I had one of their 396 on Trumbles dyno it made 475 ran that way to ,but think 535 would be a good one.
#9 | |
"very good ones make 600 range " I would open this question up to the whole forum, if you have a A/SA 1969 Nova with a 375 HP 396 stick and it runs 135 MPH @ 3470 in a 29.00 baro, How much HP does this take? With 245 CFM @ 28 inches it would have to make in the 530s for HP corrected STP. My Buick flowed 213 CFM @ peak lift and made 474 HP, theres no way that BBC intake manifold is worse than the Buicks. Last edited by HP HUNTER; 04-09-2017 at 10:33 PM. |
[QUOTE=HP HUNTER;531772]"very good ones make 600 range "
I would open this question up to the whole forum, if you have a A/SA 1969 Nova with a 375 HP 396 stick and it runs 135 MPH @ 3470 in a 29.00 baro, How much HP does this take? With 245 CFM @ 28 inches it would have to make in the 530s for HP corrected STP. My Buick flowed 213 CFM @ peak lift and made 474 HP, theres no way that BBC intake manifold is worse than the Buicks.[/QUOTE What buick are you talking about? The 455 is way better than the 365/454 intake. |
