Liked 325 Times in 50 Posts
As most people know Class Eliminations are laddered based on a Sportsman Ladder. Someone from NHRA approached us at No Problem with a problem that has developed. A little history; Some years I approached NHRA about the ladders after Indy which became a problem with everyone trying to get someone, miss someone, or pulling straws all of which made Class in Indy a mess and hard to administer and keep the program on schedule. In my proposal, I only intended Indy to get this treatment. NHRA instituted it at all National Events which was OK at the time. However with three day races becoming the norm, it is almost impossible to get the ladders done and so the delays that now exist and with sometime one time trial and then class it gets worse. His suggestion to keep laddering was to institute a regulation that you had to run the class you entered in. We had no problem with that, but told him we would need someone to change class from when we entered until registration closed usually on the Monday before the race. And we know there would have to be a couple of things worked out before this could be done either way. This is asking for comments on this idea, and the NHRA person is looking at any problem from their side. We did not address the fact that you have to have a run to get a time before the ladder can be done, but he seemed to have this handled. Comments, Ideas, or what have you.
Jeff Teuton 4022 STK |
Liked 1,820 Times in 425 Posts
No thanks. Can't change classes. No hiding. Just pick card. #s . Flip cups. Faster car gets bye run. Done
james perrone 1290 STK |
Liked 444 Times in 145 Posts
There's no reason to change anything. The ladders have helped tremendously with keeping peace in the lanes. Nhra simply has to assign a person with the responsibility of getting the ladders out in good order and in a timely fashion. This does not mean that this would be the worker's only job during the race. If they can't seem to get it right they could farm the job out to one of the software companies like Portatree. The racers could get a text with the ladders when their category is called up. There is no reason for this to be as difficult as they have made it.
Bruce Noland 1788 STK |
Liked 10,693 Times in 2,227 Posts
I like class being laddered, if its done correctly its simple and fast if not its a cluster. I have no problem running the class entered. Possible draw backs; some one has hit your combination after entering and car will not "fit" the class that it was originally entered, remember the adjustments for a 1.20 under run is posted on Tuesday. Mid year AHFS adjustments change the class the car will "fit'', and you entered three weeks earlier before the category closed in a different class.
If racers can change classes on Monday of the event week, will it cause system overload? I bet Toby can do it! |
Liked 584 Times in 94 Posts
I'm confused... I don't see any relationship between what class you run and the timeliness of getting a ladder done...You still have to make a run first...I get it that some of the NHRA tracks still use Dos as an operating system, but in our current day and age of technology ...come on , give me a break,... most of the new cars engine management systems could generate a ladder! This sounds like some BS thing, a self serving racer has thought up to try and hide from the faster cars in their class before they enter a National Event.
HOW ABOUT THIS - Just to make things simpler (faster) for the sanctioning bodies - Why don't we register our cars at the beginning of each year !... You must declare the year, make , and model, and THE CLASS you're running for that year. Then you get you a certification sticker - No changes until January 1 the following year. LMFAO ......
Liked 1,428 Times in 296 Posts
I say don't change it. Just improve the process to ladder the cars. It can't be too difficult to have software done or some other automated process.
Even if they had to export the qualifying to excel and sort it, it would not take long. The biggest challenge I saw at Gainesville for class was poor communication between the tower and the people working in the lanes.
James Schaechter 3163 STK |
#8 | |
Liked 161 Times in 52 Posts
Stephen Johnson #2162 Horace Johnson #2167 SS/D 427 Ford Fairlane NHRA-IHRA |
Liked 316 Times in 67 Posts
Ummm, bring Red back?
Liked 232 Times in 39 Posts
I agree......leave it alone!
Marty Buth 3657 STK |
