#131 |
Ed nailed it!
Ed Wright 4156 SS/JA |
#132 | |
Guest
Posts: n/a
To me the king is crowned at Indy. Done. |
#133 |
Liked 684 Times in 289 Posts
Are there any Fords in the mix?
Mike A114 P/SA |
#134 | |
Liked 174 Times in 39 Posts
1993-2002 Camaro/Firebird: Cd = 0.34, A = 22.0, CdA = 7.48 C5 Corvette: Cd = 0.29, A = 21.3, CdA = 6.18 (note the Z06 is higher) A C5 is actually better than a Cobalt, and a third gen is actually better than a 4th gen. Obviously this is at stock ride height with stock wheels/tires, etc, so it would change some for a drag car. That being said, if you do the math, it's only a few hundredths difference.
3207 D/SA, C/ED Last edited by Andrew Hill; 04-26-2017 at 10:29 AM. |
#135 | |
Don't know how much you know about class racing, but the Camaro and Firebird started there lives @ 305hp. They now are 381 because of ego runs, and I can see it happening again in this situation. Alan will play him all the way to horsepower. On the other side the Camaro is definitely the FASTEST LS1 I've ever seen @ 3405 pounds. Jeff Longhany |
#136 | |
Liked 20 Times in 14 Posts
#137 |
Liked 10,907 Times in 2,255 Posts
Being an LS1 follower for years, you can stop smiling any time now Albert Lee, I believe the 346 LS1 in a Corvette is at factory horsepower of 345. If I remember correctly the flat hood cars were @ 305 hp and the fresh air cars were @ 320 hp. I could be wrong, but I always try to pay attention.
#138 |
Liked 80 Times in 29 Posts
In all candor, if either car is that quick - or any for that matter, it sounds like the system developed to look after unbalanced performance levels such as this should be allowed to work. Why have the AHFS in place at all? If the system is valid and effective, let it work.
#139 | |
The data I posted is from from actual testing done for General Motors at my former employer's wind tunnel. Although General Motors has its own wind tunnel, it was not available to the public or racing teams until 2009. Prior to 2009, GM contracted the wind tunnel testing with outside vendors. This is the same wind tunnel were Warren Johnson tested his new Pro Stock Firebird late 1998 and ended changing the shape of the quarter panels and rake of the car. When he showed up at Pomona in 1999, he had to redo the quarter panels with a hammer on his car after he was protested by others and eventually Rick Jones re-skinned the quarter panels to the likes of NHRA. It is the same wind tunnel were Warren learned first hand how much drag and horsepower penalty is on a hood scoop. |
#140 |
If all else was equal, I'll take the 7-10% reduction in drag coefficient.
Interesting comment regarding the hood scoop. I did the calculations on many Super Class scoop designs and determined the cars would be faster with the scoop reversed or no scoop at all. One racer even admitted that was the case based on his testing but thought it looked cool so he left it as-is. Hold a flat palm out the window at 60, 70 or 100 mph and you'll quickly see how much force is applied. It certainly eats power. |
