Old 03-21-2017, 01:32 PM   #21
njk53
Default Re: Thermo-quad Tips
Just out of curiosity, who can do a decent restoration on a stock Thermo-Quad carburetor. I picked up an original 73 340 Duster and the car currently has a Holley carb on it and the original Thermo-Quad was in the trunk for obvious reasons. The car sat for about 15 or so years. I checked the plugs, cap, rotor etc. put fresh gas and a fresh battery in it and the car lit off with little issue. It ran and idled remarkably well with great oil pressure. I would like to get the Thermo-Quad done by someone who knows the tricks to make it work for street use and make it look half way decent to the eye.
Nelson Kowal
Stock 345
Old 03-21-2017, 02:16 PM   #22
GTX JOHN
Liked 2,486 Times in 697 Posts
Brad Van Lant or George Thompson are outstanding carb builders!
Really optimizing the jetting/Air Door/Accel. Pump are all the tuning
a street car requires. Try different settings and working to find out what the vehicle likes.
Use Air Bleeds to get best idle quality is something we probably all know to do.
John Irving
741 Stock
741 Super Stock
Old 03-22-2017, 05:32 PM   #23
Rod Greene
Liked 242 Times in 81 Posts
Go to Moparts.com web site type in Scott Smith in search engine. He does fantastic work and is what you are looking for in a street engine application.
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects.
Rod Greene is offline   Reply With Quote
Old 05-01-2017, 11:35 AM   #24
dusterfinland
Liked 4 Times in 3 Posts
Hi.last weekend at dyno have problems with thermoquad i have 2 fresh race carbs and both same thing.when secondary opens and dyno puts load against motor it dies test tifferent fuel press and bigger secondary jets nothing different.I but 750 vacuum holley it screams to 7000 rpm no problem at all..any tips.thanks and greetings from finland.
dusterfinland is offline   Reply With Quote
Old 05-02-2017, 06:04 AM   #25
GTX JOHN
Default Re: Thermo-quad Tipsk on these
Increase Air door Tension.
Work with Air Door Opening amt.
I am assuming carbs are put together correctly and floats
adjusted to specs.
Several books on these carbs still available.
If you supply Carb #.....I can give some jet suggestions
and Air Door starting openings.
Sometimes you get carbs that just do not work worth a *****
no matter what you do with them.
John Irving
741 Stock
741 Super Stock
Old 05-03-2017, 06:44 AM   #26
S/ST 3040
S/ST 3040's Avatar
adjusted to specs.
9800S?
Thank you!
S/ST 3040 is offline   Reply With Quote
Old 05-03-2017, 06:57 AM   #27
GTX JOHN
.074/.075 primary (Holley) no metering rods
.143 Sec. with .790 Air door
OR
.137 sec with .750 Air Door
(Stock unmodified Air Door specs.)
3 turns on Air Door spring tension
These are conservative but will be good baseline in my opinion.
Do not modify emulsion tubes!
9800 Series are excellent carbs to start with.....a replacement carb
calibrated better than the factory installed stuff.
John Irving
741 Stock
741 Super Stock
Old 05-03-2017, 07:20 AM   #28
S/ST 3040
S/ST 3040's Avatar
Thank you sir! I will swap my .149 secondary jet for one of your recommendations.
Are Thermoquads sensitive to fuel pressure? (I usually run 5.5 psi)
Old 05-03-2017, 12:45 PM   #29
dusterfinland
adjusted to specs.
My thermoguad number is 6545s and second is vin 6453S thanks
Old 05-03-2017, 05:49 PM   #30
GTX JOHN
Is your Duster 340 ( High or Low Comp.) or 360.
They have different size primaries (1 3/8 vs 1 1/2).
I will research these carb # and make sure correct for
vehicle as well.
John Irving
741 Stock
741 Super Stock
