Old 05-09-2017, 05:57 PM   #51
Default Re: Rd #3 Stock @ Atlanta
Originally Posted by Lenny5160 View Post
What are the 'both ways' here? Seems consistent to me. If you stage on it, you own it, period.
Maybe the incorrect dial is allowed by the rules and maybe it isn't. In either case, if you stage on it, you own it.
Both ways comment would apply to those who say someone should be disqualified 4 an over the index dial........One which they did not submit.
Old 05-09-2017, 06:57 PM   #52
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
'First' only applies if the infractions are of equal severity. If your opponent red-lights but 8 seconds later you hit the wall, you will be DQ'd for having the worse infraction.
I'm not sure where 'dial-in over index' would fall on the hierarchy of infractions; just pointing out that your 'end of story' statement because it is first would not be accurate.
Wrong.......
The first will always be the first......
Other than crossing the center line or outer boundary (wall)......
The first is a DQ......
Bob Mulry 7516 STK
A & M Motorsports
Old 05-10-2017, 06:49 AM   #53
Liked 10,835 Times in 2,252 Posts
I hope the SRAC and NHRA will address this and set the procedure and practices so we all know the rules.
Old 05-10-2017, 09:09 AM   #54
Bobby DiDomenico
Liked 101 Times in 52 Posts
Austin,
I think the 'Dialing Under The Index' section of Race Procedures, Section 2, Page 5 would cover it:
DIALING UNDER THE INDEX
Contestants in Super Stock and Stock have the option of dialing under
their class’ assigned index. It is the responsibility of each contestant to
place the selected time on the windshield and tower-side window prior
to each round of competition. Dial-unders may be changed between
rounds, including a rerun situation. All contestants not choosing to dial
under will automatically be handicapped on the basis of their assigned
class index.
In cases where two cars of the same class are paired, the
race is conducted on a heads-up basis, regardless of any dialing under
considerations, and breakout rulings do not apply.
So, by the rule, you can dial whatever you like but you SHOULD be automatically capped at the class index. Interesting can of worms with this run, for sure.
"All contestants not choosing to dial under will automatically be handicapped on the basis of their assigned class index." This is what lead me to believe the system wouldn't allow a dial over your index to be entered. An "at or below" in the line of code.
Old 05-10-2017, 09:57 AM   #55
t.tosto
Liked 62 Times in 23 Posts
Seems to me the rule is clear, must dial at least the respective index or lower. Why is it unreasonable to expect the dial-in to be correctly entered when starting line crew all have headphones to communicate to tower? I'm sure Jim had the dial visible on the car, I guess bottom line is to do your job and everyone else's.
t.tosto is offline   Reply With Quote
Old 05-10-2017, 10:03 AM   #56
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
When you staged, you signed off on it. The source of the dial is irrelevant.
The way the rule is written, there should not be a DQ for dialing over the index. Dialing under the index is simply a choice, and if you choose not to you "will" automatically be capped at the index.
S/ST 51
S/C 53
Old 05-10-2017, 10:27 AM   #57
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Originally Posted by Bob Mulry View Post
Wrong.......
Negative! The rule is FIRST OR WORST! If the second is worse than the first then second is out! If you red light and your opponent is light at the scale or his fuel is bad etc... he is out, you are back in. Period. Jim
Old 05-10-2017, 11:10 AM   #58
Jason
Liked 6 Times in 4 Posts
If you are the one entering dial-ins on the computer and your "friend" is racing, just put in a dial-in over the index for the other lane. If it is caught, no harm no foul. But by current rules, if it is accepted, BINGO.....your "friend" wins.
New rule proposal. "If a dial-in is entered wrong by the tower and can be proven after the run, a rerun will be allowed."
Jason is offline   Reply With Quote
Old 05-10-2017, 11:25 AM   #59
GUMP
Liked 2,359 Times in 557 Posts
Why should I have to subject my car to this just because you forgot to read your dial?
GUMP is online now   Reply With Quote
Old 05-10-2017, 11:30 AM   #60
G Schenck
Liked 81 Times in 35 Posts
[QUOTE=Jason;534412]If you are the one entering dial-ins on the computer and your "friend" is racing, just put in a dial-in over the index for the other lane. If it is caught, no harm no foul. But by current rules, if it is accepted, BINGO.....your "friend" wins.
New rule proposal. "If a dial-in is entered wrong by the tower and can be proven after the run, a rerun will be allowed."[/QUOT
Old Rule: If your dail in is wrong, don't stage.
G Schenck is offline   Reply With Quote
