Old 05-23-2017, 11:03 PM   #1
Chipper Chapman
Chipper Chapman's Avatar
Liked 166 Times in 71 Posts
Default Spring Pressures
New cam going into our 454/365/355 this week, and I'm wondering if we have enough spring pressure. Springs are testing the same as when I put them in, only about 50 passes on it but the cam was used and outdated when we built the engine. It's a .460/.480 lift with current springs setup to be 200# on the seat, 390/400# over the nose. I've recently heard of setting springs up so they are within .050 of coil bind over the nose which would net me around 460-470#. Also it is getting solid lifters. Does any of this seem to be in the ball park or should we be going for more?
Chris Chapman
1969 Chevelle
NHRA F-G/SA 1090
Old 05-26-2017, 12:06 AM   #2
Jim Hanig
Liked 99 Times in 49 Posts
Default Re: Spring Pressures
If you have tool steel or smith lifters 200 should be good.
