Liked 455 Times in 147 Posts
Having trouble getting the secoundary's jetted properly. Have several questions regarding rod sizing and tip lengths
Smaller the final tip size, does it always mean the richer the mixture? Do the tip lengths S, M, SM and L effect rich or lean condition with the same tip final size? Why are LL tips never to be used in greater than 70% air valve opening? Wanting to start on the rich side, is there good rod and hanger letter numbers to start with for a SBC 350 stocker for sea level conditions? Tension on the Air valve. What effect does the tension have in 60ft times? Is it better to be on the loose side or on the tighter side using a 2 step WOT?. Thanks to everyone for the help ![]() |
Liked 310 Times in 174 Posts
The tip of the secondary rod sits in a fixed size orifice and acts as a restriction. So yes, the smaller the tip the richer the mixture. "They" say the long rods work better in drag racing but I have never seen any difference in testing. Don't know what LL tips are. Most guys measure tip diameter size for tuning, I go by factory stamps. An AU or CK rod is fairly rich. You really need a tool to properly measure the hangers. You can not go by the stamping. B or C hanger is on the very rich scale of things. The tension on the flap should not be to loose or a bog will surely appear. Don't think you will find much in the 60 with the flap once you have it set.
Liked 1,937 Times in 582 Posts
A good starting rod size is a .057 rod. Hot weather a .066 rod is what I use. J or K hanger is also a good starting spot. Beachy Machine makes the tool to check the hangers as I remember. Not sure if they still make them.
Mike Pearson 2485 SS |
Liked 358 Times in 83 Posts
Mike Pearson is 100 percent on the money with his response. I bought a Beachy tool a few years back and Mike (Beachy) told me that at that time, they still had a few and would happily sell them.
Liked 205 Times in 93 Posts
how do we get ahold of beachy tool?
Liked 6 Times in 2 Posts
LSM had a hanger checker - I'll post a picture later. Not sure if they still make it.
Mike Semeniuk 632 GTMA |
Liked 129 Times in 59 Posts
I spoke to the folks at Beachy's in Kokomo, and the gentleman who created that tool has retired. I left a message at the number I was given for him, and I'm just waiting on a call-back. I'll update y'all when I have more information. How many folks would be interested in such a tool if it was made available?
Lew
Lew Silverman #2070 "The Wagon Master" N/SA |
I use a LSM tool. Saw it listed on their website. QJ-100 hanger alignment tool $39.00
Liked 73 Times in 36 Posts
Forum Folks that might be interested in an easy solution to measuring QJet Hangers:
Easy to build out of scrap stuff. Center piece is 1/8" aluminum but could be steel or whatever. Bottom is built from couple of pieces of 3/4" x 1/8" angle iron so it is easy to keep upright when used. Will include a few photos for reference. Most folks do not need this kind of accuracy but it is easy to use anyway. Soon as I figure how to resize the pics that is. Measure from the top surface to the pin (0.067" diam) with dial caliper. Regards to All, Dissident Last edited by Dissident; 06-06-2017 at 10:33 PM. |
I made up a fixture to measure the hanger dimensions. Pretty easy to do. I had several Q jets so I sectioned one so I could see exactly how the secondary rod changes with hanger letter changes. K, G etc.
What I experienced on the Dyno, using LL .040 tips rods , thinking I was riching the secondaries, it went lean. Dont understand why??? I found the primary side jet size numbers can be way off, BEST to flow every jet you have to know for sure which way you are really going with your jet changes. Thanks to all that responded. |
