#11 |
Liked 314 Times in 177 Posts
LL tip rods must be primary rods. I don't think anybody uses primary rods anymore in a race QJ.
#12 |
Liked 27 Times in 19 Posts
The largest tipped rod I've used in my street machine has been .052. Usually in the mid .040's to end up 12..5 -13.2 afr.
#13 |
Liked 707 Times in 284 Posts
Here is what I did to measure hangers. Some with the same hanger letter measured differently.Put hanger on end of caliper and use the same drill bit and measure distance and record. If you look close to this hanger it shows as being cut. That made it adjustable. Just bend at cut and remeasure. I believe this hanger came with my first Hedworth carb back in 1991.
![]() Last edited by Jeff Stout; 06-07-2017 at 12:55 PM. Reason: more |
