Old 06-08-2017, 05:43 AM   #11
Steve Stasko
Liked 274 Times in 143 Posts
Default Re: what stock eliminator class?
Out of curiosity, is the car a Hardtop or a Sedan? My Grandfather had a brand new '65 383/330 Sedan. It ran C/SA then!
I agree with Mark also, if you think the 516's and the carb are detrimental to the combo, you need to rethink your plans. Plan on spending most of your money on the heads. It's not going to be a "dime rocket" for sure, but it also shouldn't break the bank to build it and be somewhat competitive.
Old 06-08-2017, 11:16 AM   #12
James L Miller
Liked 25 Times in 16 Posts
I would think the bowls in the Edelbrock exhaust ports would need welded up and smaller seats put in for the 1.60" exhaust valves. I guess since they allowed "any valve job", welding the area under the seat is OK and then remachined? Or do you have to leave a big step under the seat since welding isn't legal on a Stocker head? Is the NHRA legal head coming with valve seats installed? I think they were, not sure if they still are.
Mopar 2 Ya!
Old 06-08-2017, 01:25 PM   #13
Svendsen
Liked 55 Times in 4 Posts
The 915 heads are better than the 516 heads. Those 915 heads are from 1967, where two versions were produced by Mopar, one with a 1.60 exhaust valve, the other with a 1.74 exhaust valve. Of course, you have to use the version with the 1.60 exhaust valve. Dean Oliver does a great job setting up the AFB for stock. We used CP pistons, which were flawless. If you can afford it, use the legal aftermarket rods specified by NHRA.
A few years ago, I wrote a Car Tech book, with huge help from Jim Hale, on building a 383 for Stock for my someday soon '66 Coronet stocker. It might help you decide if you want to run a 383.
Arvid Svendsen
ID:	40171   Click image for larger version
Svendsen is offline   Reply With Quote
Old 06-08-2017, 01:51 PM   #14
Coleydog
Liked 53 Times in 38 Posts
Not totally sure but I think those E heads come with the small ex valve and closed chamber. The reason so much has to be done ($$$) to be like a 906. I have a 65 4door Plymouth (273 or 383) that I've been thinking what if...
Old 06-09-2017, 12:22 AM   #15
James L Miller
http://www.edelbrock.com/automotive/...approved.shtml
http://www.edelbrock.com/automotive/...r-rpm-bb.shtml
"Combustion chamber volume: 75cc / 84cc / 88cc
Intake runner volume: 210cc
Exhaust runner volume: 70cc
Intake valve diameter: 2.140"
Exhaust valve diameter: 1.81"
Valve stem diameter: 11/32" "
I think someone said they weren't cutting the seats, so that would help with the standard 2.08"/1.74" valves. Then you need to ream the guides for 3/8" stems.
Mopar 2 Ya!
Old 06-09-2017, 08:43 PM   #16
Coleydog
Just checked, no seats cut
Old 06-09-2017, 09:45 PM   #17
David Lee
Liked 346 Times in 126 Posts
get a hold of shane studley on facebook.
Old 06-10-2017, 01:46 AM   #18
Paul Precht
Paul Precht's Avatar
Liked 320 Times in 119 Posts
Originally Posted by brutuswedge View Post
Thanks so much for your info & help. We are in southern Ohio. Very fortunate here; close to Trails in Columbus, Norwalk, Quaker City, the new 42, Mt, Vernon, Magnolia, Marion County, or Larue. Wanted to write more, but could't figure out how to edit, but, how much of a detriment do you Chrysler guys think those little 516 heads & tiny afb, I know I have to run, would be? I'm just not slippery enough to know how to figure out how to get a set of 906 heads, a late model intake & a Holley past tech. LOL! (Bet it would run then) Thanks again. Bob
The 915 head is legal and the ports are basically identical to the 906, the biggest issues are the small carb,566CFM on my bench and the lack of V to P clearance, that said it's a great combo at that HP Factor.
Paul Precht is online now   Reply With Quote
Old 06-10-2017, 08:39 AM   #19
Greg Hill
Liked 279 Times in 68 Posts
You are close to a really good stock eliminator engine builder in Dayton. Parsons and Myers have a history of fast mopars and other makes as well.
Greg Hill 4171 STK
