Old 07-03-2017, 03:15 PM   #1
David Lee
Liked 346 Times in 126 Posts
Default Question on Mopar front suspension
I am about to start rebuilding the front suspension and steering on my 67 cuda. Re there ant preferred control arm bushings and balljoints to make the front end work better for launch?
Thanks
Old 07-06-2017, 08:05 AM   #2
Jim Bailey
Liked 584 Times in 94 Posts
Cool Re: Question on Mopar front suspension
If you have the budget and only want the best, contact Kim Rhoads in Pa....I don't have his number, but I'm sure someone does.
Jim Bailey is offline   Reply With Quote
Old 07-06-2017, 02:47 PM   #3
lorenr
Liked 19 Times in 9 Posts
Thumbs up Re: Question on Mopar front suspension
If you have the money and wish to do it right, switch it over to any A body after 1967. They are different and stronger (better engineering).
K member and related parts bolt right in. Also, as I recall, there are a few race related front control arms that are better and have better bushings.
lorenr is offline   Reply With Quote
Old 07-06-2017, 03:30 PM   #4
340Cuda
Liked 802 Times in 339 Posts
Default Re: Question on Mopar front suspension
Yes, the idler arms after 67 are better and much easier to find.
Good luck!
Bill
Old 07-06-2017, 04:55 PM   #5
David Lee
any year after 67 as far as the control arms and related parts?
Old 07-06-2017, 05:56 PM   #6
James L Miller
Liked 25 Times in 16 Posts
The 1967 idler arm has a stud on the pivot end and the K-member has one tab. I replaced the idler arm on my 1967 Dart and it seemed like it needed replaced again within a couple of years. I'm going to replace the whole K-member and suspension with disc brakes from a 1973 340 Duster with the spool engine mounts. I'd probably switch to the 1973-6 spool mount K-member. The sway bar is different as it goes through the K-member. I'm not sure if the 1968-1972 idler arm could be adapted by welding on another tab for a double shear arrangement with a thru bolt?
Mopar 2 Ya!
Old 07-06-2017, 06:35 PM   #7
Frank Bialas
Frank Bialas's Avatar
Liked 23 Times in 13 Posts
Thanks
P M me
Frank Bialas 1570 STK
Frank Bialas is offline   Reply With Quote
Old 07-06-2017, 11:20 PM   #8
mopacltd
Liked 124 Times in 44 Posts
Has anyone replaced bushings with bearing like the Cheby guys?
mopacltd is offline   Reply With Quote
Old 07-07-2017, 08:05 PM   #9
Coleydog
Liked 53 Times in 38 Posts
Yes I have, lca with bronze bushing in a steel housing and uca with aluminum-steel bushings. Both have grease fittings. Hope they work, definately free moving. If they don't I'll re-engineer till they do. Pictures for $10,000 LOL
Old 07-07-2017, 08:10 PM   #10
David Lee
where did you acquire these?
