Old 07-25-2017, 12:24 AM   #1
Everett Vassar
Liked 2 Times in 2 Posts
Default O2 sensor question
Installing a single o2 sensor/logger in the header collector. Does it matter which one? Does it need to go right behind where the tubes go into the collector? Or further back?
Everett Vassar is offline   Reply With Quote
Old 07-25-2017, 12:42 AM   #2
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default Re: O2 sensor question
Good info in this old thread... http://www.classracer.com/classforum...dvanced+timing
Sensors installed in a open collector will give bogus lean readings at idle/slow speeds...just a heads-up.
Rich Taylor
I/SA - 321
Old 07-25-2017, 05:40 PM   #3
slick5861
Had the same questions. I called the tech line at AEM were I purchased the AF unit from. Those guys answered all my questions about placement and why the readings were what they were in regards to placement, of the sensor, in the collector. Very knowledgeable and helpful.
slick5861 is offline   Reply With Quote
