Old 07-25-2017, 08:16 PM   #11
Woodfin
Liked 288 Times in 109 Posts
Default Re: 3074S M/T, a confusing and frustrating happening
Racers, I bring this topic back for an update.
To review, I installed, simply for maintenance, a new set of M/T #3074S [32 x 14 x 15S] The old set, although performing well, was two plus years old with many runs.
These are on my S-10, Super 10 super stocker that I also bracket race. It runs 6.30 - 6.40 in the cooler months, 6.40 - 6.50 in our Texas heat.
The stiff side wall has worked as expected for me with several other packages. Also, with my Truck, it has a 5.57 rear gear, 1.98 low and 6600 converter so it hits hard at the trans brake release, even with the small 327 engine.
So, again to review, the first outing with new tires produced chatter and slip. [same tire, same part number, same air pressure] I even talked with M/T to verify the tire was the same design, no changes.
After two frustrating outings of chasing the cause, and chasing the dial, and chasing the reaction times, at the recommendation of another race who runs the same tire and similar weight and performance, I made a drastic [for me] change. I am not prone to make large changes, I am usually slow and methodical with changing.
AnyWho, even though the truck had worked well at 11 pounds with old tires, and even though the general feedback was "hitting the tire too hard, needs more air" [we had it as high as 13 pounds]
Well, just go figger, dropped air pressure to 8 pounds and voila, dead hook with the expect ET.
It would be reasonable for a person to expect, at my age and with my experience, such lessons would have already been learned, yet, that expectation is wrong. It is my observation that the lessons are an on-going and never ending process.
Old 07-28-2017, 08:48 AM   #12
Mike Rietow
Mike Rietow's Avatar
Liked 30 Times in 16 Posts
It might not be the new tires.
Mike Rietow is offline   Reply With Quote
Old 07-29-2017, 01:02 AM   #13
Adger Smith
Liked 880 Times in 311 Posts
It needed lower air pressure to "Work the Sidewalls" I ran into the exact same thing years ago with some 12" Firestones that we ran on a Super Stocker. We only ran the car at two racetracks and the car did the same thing at both tracks. Same deal as you Larry, small changes for me, but it took a real big change to get to the sweet spot that made the sidewalls work. I never got a picture of ours, but the wear on the tire looked like it had the sides hitting way harder than the rest of the tire. With the sidewall softer the footprint looked more even. I would just write it off to the way the MFG processes are. A Cooper tire plant is about 6 blocks from my home. I know a lot of tire builders and to hear them talk it is not rocket science.
Adger Smith (Former SS)
Old 07-29-2017, 08:09 AM   #14
Woodfin
Adger,
I have come to the same conclusion. The new tire sidewall is more robust than the old tire. Thus, requires less air pressure so the sidewall can work as designed.
We did employ a diagnostic tool, a cell phone video. It is amazing the video a modern cell phone can produce, vivid color, slow motion, stop motion, expand, what a tool!
Old 07-29-2017, 08:53 AM   #15
Woodfin
to review, the confusing part of this issue is that I never had it happen before. [that is to say, never installed a new tire replacement of the same tire and had to change air pressure]
Of course, in hind sight, I now understand the happening.
"Drag Racing, a life long learning process"
Old 07-29-2017, 09:53 PM   #16
Adger Smith
Didn't have all this modern Tech back in the late 60's and early 70's did we Larry. We night have been real dangerous if we had... even a weather station!
BTY: I started tracking some weather after I got my pilot's license in 1969. Before that I never knew what Air Density was.
Old 08-03-2017, 11:47 AM   #17
Jim Parsons
Liked 196 Times in 31 Posts
I have been fighting this same MT tire issue/ inconsistency for over a year with a bracket car I mess with. Worked on the front end thinking it was about no pitch rotation hitting the tire, then shocks front and back, leave RPM, ladder bars, and even loaded the trunk with 80lbs. of weight!
Took your suggestion and went to the track last night and dropped the pressure from 11.5-12 psi to 8.5 psi and 60’ are back with in .005 for five runs.
Thanks
Jim Parsons
Jim Parsons is offline   Reply With Quote
Old 08-03-2017, 12:21 PM   #18
Dragsinger
Liked 99 Times in 60 Posts
Jim,
in other discussions, it has been suggested that a running production changed occurred with "something" about that tire. [no body knows, just suggested]
Like you posted, I have experience with the tire not just on my S-10 but other packages.
The past experience handicapped me from testing lower air pressure. Yet, can't argue with what works.
A bit more feedback, after three frustrating outings I walked to the starting line and watched the tires of other cars with similar weight and performance. The cars that were dead hooking had a pronounced sidewall wrinkle. Then watching my truck video it had none to very slight wrinkle.
Back at my parking spot the racer next to me had the same tire in a similar package. He was running 8 pounds.
Go figger.
Larry Woodfin 471W
Old 08-03-2017, 10:31 PM   #19
Stick Racing
I could have jumped in here a little sooner on this subject.
I run with the Pro Stick group in the Mid Atlantic area. The 3074ST tire is run by well over half the cars in the group.
I remember most guys would run 10- 12 lbs or more in those tires with good results. Usually adding air would make them work better. Then at the beginning of last year, the guys started to complain the tires weren't working. So they started playing with the air pressure and noticed they now work better at lower (7.5-9lb) of air pressure. A phone call to M/T confirmed that they did make a change in construction and we were told this tire was 'using Pro Stock technology' and it uses less air to work properly.
This is the story I got, true or false. I do know these tires work better at a lower air pressure than years past.
Andy Stone 1102 A/S 1112 SS/C
Stick Racing is offline   Reply With Quote
Old 08-04-2017, 04:49 AM   #20
Adger Smith
Do those MT Tire grow much?
I am looking at the MT 3073W 31.25/12.2-15W
to replace the 14.5 X 30.5 Goodyears that I had on My SS/DS.
I need a little taller tire, but can not go too tall due to wheel well issues.
The GY's were 96.25" roll out these MT are 98"
The GY's were an old Comp tire ( I think they were 1702 or 1902) with stiff side walls that is discontinued.. It worked
The MT's have the L-8 compound that is toward the soft side.
What do you guys think.
Anyone got any input on this tire?
The only other tire I have found in the roll out and size that might work is the Phoenix 13.0/31.0-15
13.4 tread and 96 roll out...Will take a small gear change
