#331 |
Liked 7,858 Times in 1,750 Posts
So just what is it about your 318 combo that you feel isn't fair?
#332 |
Liked 346 Times in 126 Posts
#333 |
Liked 314 Times in 177 Posts
If someone building a combo is so concerned about the lack of availability of an aftermarket block, then he should build a different combo and buy the block of choice. I always say, the planning is the hardest part.
#334 |
Really, you are willing to eliminate that many combos.
#335 |
But I'm not complaining about not having a replacement block. I'm complaining about combos that are being given aluminum aftermarket intake manifolds in Stock!
#336 |
David, you apparently don't know many hardcore Stock Eliminator racers.
#337 | |
Others sleeve them. A properly filled or sleeved block, machined with the right equipment and by someone that knows what they are doing, will make power. |
#338 |
Liked 43 Times in 9 Posts
I would be concerned if that 68-71 318 piston with valve reliefs is legal or not. That's a **** load of HP right there that no aftermarket block or head will make up for. Just my 2 cents.
Sam Capizzi Jr. 1301 SS/AS 93 Dodge Daytona R/SA 73 Dodge Dart |
#339 |
Liked 1,856 Times in 433 Posts
I'm all for aftermarket heads. If Everyone Can Have Them!
Main benefit of a aftermarket block is take the hone better last longer but is heaver You have aftermarket block and sleved it? Really Reinventing the wheel ?
james perrone 1290 STK |
#340 | |
Liked 327 Times in 121 Posts
